Water Pressure Gauges
Charter Member #34
SOLD SOLD SOLD SOLD Thanks OSO
Pair of Autometer Water Pressure Gauges with mounts
If you don't run water pressure gauges you are miising out on what I think is the best kept secret. A good friend and Mercury mechanic turned me on to them nay years ago and I swear my them.
Loose an impeller or water pressure and how will you know? Yeah most people know when their water temperature gauge shoots up and the engine over heats!
Water pressure gauges will tell you the minute you start your motor that you have pressure (flow) and the minute you don't.
$60.00 per pair + shipping
Charter Member #34
Nosending units required. Just put the fittings in the side of your blocks where a plug is. Use a push lock fitting like on the back of these gauges and run clear tubing (1/8 inch I think?). A tip for you is to make the tubing a couple of feet longer than needed and coil it up in the engine compartment somewhere. The reason is that over time the tubing will collect sand and dirt near the engine. When that happens all you have to do is cut off about six inches and stick the clean end back in the fitting and it will be as good as new.
Charter Member #34
