-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Aluminum Tri Axle Trailer, Needs Work, Cheap!! (https://www.offshoreonly.com/forums/swap-shop/278164-aluminum-tri-axle-trailer-needs-work-cheap.html)
Baja226sport 06-07-2012 09:22 AM
5 Attachment(s)
Quick run down, this is the trailer my scarab came on when I got it. It is entirely to small for a 31ft boat. I think it would be better suited to something in the 27-28ft range.
Anyway, it is a triple axle aluminum I beam but it was painted a while back for some reason and it is not the best looking. It is torsion arm suspension and the bearings are good.
Tires need replacing but should make a reasonable trip without issue. There are no brakes on this trailer, not malfuncitoning, there are not any period. I have a title that came with it from MD, not sure if it is actually for it, but I have a title to go with it. also, the light/wiring job is very sloppy.
Good winch and tongue jack on it. It is a bunk trailer.
$900.00 OBO
NOTE: 1 WHEEL LOOKS LIKE IT IS LEANING IN THE PICS, THAT IS BECAUSE IT IS NOT BOLTED ON IN THE PICTURE, JUST SITTING THERE, I HAD A FLAT AND JUST GOT ANOTHER TIRE.
adk61 06-07-2012 11:14 AM
see rick g he is looking for something like that
GoFastSonic 06-07-2012 11:46 AM
[QUOTE=Baja226sport;3704721]Quick run down, this is the trailer my scarab came on when I got it. It is entirely to small for a 31ft boat. I think it would be better suited to something in the 27-28ft range.
Can you send back my plate ??
smokin' gun 06-07-2012 12:51 PM
Pm sent
Baja226sport 06-07-2012 01:27 PM
Originally Posted by smokin' gun (Post 3704861)
Pm sent
replied
jason y 06-07-2012 05:39 PM
what size tries and lug is it. how do you think a 255 formula would fit on it.
Philm 06-07-2012 06:08 PM
What size tires, what size axles, what is the weight capacity of the trailer?
Baja226sport 06-07-2012 07:20 PM
I have a set of bad tires on 14" and a set of bad tires on 13" rims. Some of the 14" are flat, none of the 13" are but they are dry rotted.
5 lug.
If you moved the bow stop back you could use it for that boat, and have room for a tool box on the trailer.
Baja226sport 06-07-2012 07:22 PM
I am not positive on the max weight, I will look for a tag on it tomorrow. I know my scarab is about 8000 lbs and it bottoms the suspension out.
I am not sure what you mean by axle size.
Philm 06-08-2012 08:25 AM
Axle size and overall weight capacity are basically the same thing, sorry. Was asking about the weight capacity of each axle. For example 3500lb axles.
