2 Water Cooled Chain Boxes >
Old 12-29-2012 | 02:12 PM
Default 2 Water Cooled Chain Boxes
Selling two water cooled chain boxes. These are used with super speed master drives. They let you mount the engine and trans side by side and have the drives mounted close together like with staggered engine configuration. They are clean and ready to use. hold up to 1000 HP plus. 440 983-1554
Attached Thumbnails 2 Water Cooled Chain Boxes-ebay-003.jpg   2 Water Cooled Chain Boxes-ebay-004.jpg   2 Water Cooled Chain Boxes-ebay-005.jpg
legend is offline
Old 12-29-2012 | 10:18 PM
how much you looking to get?
adk61 is offline
Old 12-29-2012 | 10:46 PM
interesting,who makes them and how do they mount?
mike tkach is offline
Old 12-30-2012 | 12:38 PM
Are these 1:1 ratio? Are they strictly chain drive?
delsol is offline
Old 12-30-2012 | 12:44 PM
Default Morris Chain Boxes
They where spares for the Rascal but the first set bought never had a problem. They bolt up to the tailstock of the trans. and then this distributes the power in,down or in and down to the input saft of the drive using the u-joint. This is used when the centerline of your trans. is to wide for the drive centerline. Allows to run the drives in close with the engines side by side if you dont have room to stagger the engines. 1:1 Ratio and smooth. (90 weight filled and water cooled.
legend is offline
Old 12-30-2012 | 03:01 PM
Very cool. Kinda like the old Arneson 1600 style drives.
MILD THUNDER is offline
