-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   EMI Thunder manifolds (https://www.offshoreonly.com/forums/swap-shop/289482-emi-thunder-manifolds.html)
OCCJoe 12-31-2012 12:29 PM
3 Attachment(s)
BBC(BIG BLOCK CHEVROLET)Bought new and have only ran about ten hours always finishing my day in brackish water and flushed with salt away. Comes with new gaskets for block side . $500 + Shipping . Call or text 910-545-3974
vtformula 01-01-2013 06:48 PM
sbc or bbc??
OCCJoe 01-01-2013 07:47 PM
Seriously I'm in the twilight Zone !
crf311 01-07-2013 02:33 PM
Do you have risers also?
oregondunes 01-07-2013 04:43 PM
Do you know why EMI stopped producing and using the "thru" gaskets between the risers and manifolds ?
Mine came that way and when I went to polish them up, EMI said they dont make those gaskets any longer. They only sell the "blocked" gaskets and you have to run the bypass hoses.
FIXX 01-07-2013 04:53 PM
fixx
theyt started block off the water ports because they did not want the water to leak past the gasket and fill the cylinders with water..i have sold a few sets and when i serviced the boats i put them on eddie sent me the closed gaskets and the bypass hose kit..they also told me to weld up the ecisting holes..so i tiged them shut and milled them flat again..no more worries..
oregondunes 01-07-2013 04:58 PM
that explains it well. thx
Randy Nielsen 01-07-2013 05:17 PM
I played hell trying to get mine to seal up on my Eliminator but I needed wedge blocks to get the risers to line up with my tips & the studs were not offset to compensate for the thickness. The riser bases would warp from tightening them down. Randy
OCCJoe 10-13-2013 10:38 PM
Still for Sale
