26 baja 468 bravo part out
10 Attachment(s)
1987 Baja 265 sport. Has a 468 50 hours on it. Gimbal bought brand new in 05 with 50 hours. Bravo drive 24p bravo 1 prop.
Motor is a 468 comp cam pro roller rockers 10qts oil pan holley carb dart iorn eagle heads gil/harden manifolds and risers pro billet msd dist. and soft touch rev limiter valve covers a bit rough, i will pull them and powder coat if wanted to color of choice. Ran the boat right around 70 never dyno'd but guestimate of 475 or so. Couple was also new with 50 hours. Steel trailer load rite with title brake inop but set up for it. has alloy wheels new tires bearing and seals just done. |
1 Attachment(s)
I haver a picture of a differant throttle shifter set up in the prev. post, those can be offered with the boat to replace the quicksilver stock 1 piece shifter. I have a rocker switch i will thrown in with it for drive trim. Boat has reupostered interior with exception of the sunpad. Alpine radio with remote cd and a set of 6x9 speaker in rear seat bennet trim tabs. Boat can be bought less power on trailer or just hull interior with no drive/ transome assembly and or with with out trailer. Has 3 monster gauges pro comp marine autometer speedo tach and water temp other gauges stock. can get any more pics you need or want
Thanks Mike |
i have a friend with a 90 dvx,,he broke the sliding door and some broad put her foot through the plastic piece next to the door...how much for both pieces?
I'd like to keep the boat whole as of now but will let you know
Thanks Mike |
How much for the gimble and the 24p bravo?
Interested in the gimble and prop.
Jeff |
The gimbal is great shape the prop is hashed a bit will get pics if still interest
Thanks Mike |
Mike you said keep it whole. Boat trailer and gimbal price? Maybe drive as well?
Interior looks decent!
Boat and trailer 3000
With gimbal 3500 With drive 4000, ill throw the prop in and shifters leave trim pump and rewire and light the trailel. They work fine but good to have new stuff Gimbal alone 800 Drive 800 Motor complete bravo drop in includes exhaust 4500 with powder valve covers of choice, less dist. With full ignition 4700 MSD blue box, soft touch rev, and pro billet 350 |
| All times are GMT -5. The time now is 05:59 AM. |
