Gray cockpit carpet
I have a piece of gray cockpit carpet that is 82"x77". It is brand new and is left over from a previous project. This is not yet cut to fit any specific boat and the sides are still rough cut. It has a white rubber bottom sonit should stay in place very well. I bought this from a fellow oso member for $100 so I would like to get that back. Email for pics [email protected]
I have some floor work to do i could very well be interested in this carpet, i would need a little time, like a day or so to stop by and measure what i am going to need for my application. if what you have will work for me i will take it.
let me know if you can give me the time to measure before you sell.
Crazy Energy
What are the weight and size limits for shipping using UPS?
UPS has established specific weight and size limits for the packages that you send with all UPS services. The restrictions below only pertain to individual packages. There are no limits to the total weight of your shipment or the total number of packages in your shipment. Shipments larger than the limits listed below will require the use of our UPS Freight services.
Packages can be up to 150 lbs (70 kg).
Packages can be up to 165 inches (419 cm) in length and girth combined.
Packages can be up to 108 inches (270 cm) in length.
Packages with a large size-to-weight ratio require special pricing and dimensional weight calculations
I sent some carpet just roll it tight wrapped it up in heavy plastic no box.
