-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Procharger setup Big block Looking to go back to stock. (https://www.offshoreonly.com/forums/swap-shop/312771-procharger-setup-big-block-looking-go-back-stock.html)
Mtuned 05-25-2014 08:10 AM
As the title states.
I had the charger setup for last couple years and its honestly just WAY more than me and my family need.
Its the bigger kit with larger intercooler, I wanna say M3 been it has been a while and I will update post once i check. Intercooler was pressure tested last year and NO leaks.
I'm looking to trade back for stock parts. It has a MEFI 3 thats been flashed by Arizona speed upgraded map sensor 42LB injectors just flowed and cleaned.
I would be wanting to trade:
Supercharger kit
Ecu
wiring harness (the map sensor plug was changed rather not get into cutting and splicing for no reasons)
I would prefer local as we can just swap the parts. But can ship if needed.
I would need to keep my fuel pump and regulator unless your willing to give up all your stock fuel stuff as well.
As far as how much cash? Im just looking to get some offers plus go back to stock. Nothing wrong with the unit, it powered my boat well above speeds you need to go in a 24 foot boat :)
Fenderjack 05-25-2014 10:00 AM
Very vague is yours a 502 or 454 And just what all do you need my friend is looking.John Sr
Tom272Baja 05-25-2014 10:25 AM
I would assume a 502 since it is listed under "my boats" under his avatar.
Fenderjack 05-25-2014 11:07 AM
Tom272 baja I'm not assuming could be anything. John Sr
a262carl 05-25-2014 11:56 AM
Tom please contact me [email protected]. I'm interested
Mtuned 05-25-2014 03:36 PM
502 big block.
Mtuned 05-25-2014 03:38 PM
Basically I'm supercharged now and want the boat back to stock. Don't need 800hp to pull tube around the lake.
Mtuned 05-25-2014 03:41 PM
Watch "Baja H2X Mike Ford Racing Engine. M3 Procharger. …" on YouTube
Baja H2X Mike Ford Racing Engine. M3 Procharger. …: http://youtu.be/90vFgwKZw8c
That's a video of it idling. End of video has supercharger in it.ill have detailed pics soon.
mallatt442 05-25-2014 06:27 PM
800 horsepower....
offthefront 05-25-2014 06:32 PM
unless there's been work to the motor its not 800, more like 600hp tops .. The PC doesnt make it go too fast, your right hand does ...how much boost you running? increase the pulley size to back the boost down and just let run .....it will run for ever .....m
