-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Kiekhaefer 280s K-Planes / Trim Tabs with Pumps (https://www.offshoreonly.com/forums/swap-shop/313409-kiekhaefer-280s-k-planes-trim-tabs-pumps.html)
ka0tyk 06-07-2014 02:45 AM
Set of used Kiekhaefer kplane trim tabs. I purchased these and didnt end up mounting them on my boat, ended up finding a set of smaller trim tabs instead... I have a 21 footer and these were just a tad overkill.
The tabs themselves have been stripped down to the aluminum, primered with Zinc Chromate, and then painted with multiple coats of Mercury Black and then coats of clear. Comes with a set of Kiekhaefer trim pumps that were also stripped and repainted, I have the bottoms removed in the pictures to show how clean they are inside with no signs of goo, dirt, or sludge but have all bolts and gasket. Brand new mercury solenoids and wiring to the motors. Trim rams move smoothly and no binding. Trim tabs measure 14"w x 19"l x 10" h.
You will need a set of hoses, which can either be purchased from mercury parts or you can have standard SS braided hydraulic lines made. Also needs the pins for the trim rams.
https://scontent-b.xx.fbcdn.net/hpho...59107827_o.jpg
https://scontent-b.xx.fbcdn.net/hpho...38445805_o.jpg
https://scontent-b.xx.fbcdn.net/hpho...04611731_n.jpg
https://scontent-a.xx.fbcdn.net/hpho...80015536_n.jpg
https://fbcdn-sphotos-a-a.akamaihd.n...63856374_n.jpg
https://scontent-a.xx.fbcdn.net/hpho...28937907_o.jpg
Asking $900 obo.
ka0tyk 06-12-2014 02:25 AM
open to offers...
ka0tyk 06-22-2014 01:23 AM
bump $750 + shipping
ka0tyk 06-24-2014 01:21 PM
mr chaos if you're reading this i cant respond to your question:
CHAOS REIGNS has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
Holy Smokes 06-24-2014 02:18 PM
Do you have the SS thru-hull fittings for the hydraulic hose connections or the SS studs to mount the planes to the transom?
ka0tyk 06-24-2014 03:38 PM
no I dont have the thru-hulls for the hydraulics. but id imagine a hydraulic hose shop could provide a threaded fitting that would work for muuuch less than a mercury part. as far as the "studs" it was my understanding that they mount to the transom with regular SS bolts...
picture of a set of "new" 280s planes... 2 thru-hulls and no "studs"
(not mine, just showing an example!!!)
http://www.thehulltruth.com/attachme...planes-002.jpg
shootitup 09-08-2014 08:56 AM
Hello ka0tyk
I send you pm have you look ?
ka0tyk 09-12-2014 03:28 PM
sorry these sold on ebay a while ago. forgot to update.
