-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   JE Pistons 257984 forged 509 (https://www.offshoreonly.com/forums/swap-shop/316113-je-pistons-257984-forged-509-a.html)
tpabayflyer 07-30-2014 02:50 PM
Rummaging around my house I forgot I had these! 4.500 bore/4.00 stroke with 6.135 rod.
C/H 1.645 includes rings/pins/spiro-locks. All brand new from JE. These are top quality 2618 forged pistons
Ideal for a blower application. I ended up going with 10.2-1 Compression with my 509 so I never used these.
I just checked Jegs and these are $785 so how about $550 shipped anywhere In the continental U.S.
Call or text 813-49four-494nine I will send you a pic of everything In the box if you like... TBF
tpabayflyer 08-07-2014 07:12 PM
Nobody building up a mean 509?? How about $500 plus a a actual shipping or free pickup in Tampa?
Jfoster 08-07-2014 08:02 PM
I'm building a 509 but I need at least 10:1 compression
tpabayflyer 08-07-2014 10:48 PM
Yeah, I did the same... aluminum heads and 10.25-1 with SRP Pistons.... I was originally going to stay with iron heads and just run 87 octane but got a deal on some Aluminum heads and decided to up my game!! Its been a pain fueling from the cans so I picked up a nice 30 GAL Fuel Dock with a nice 1/2 hose gravity feed that gets the job done fast! These pistons are really a work of art!
Jfoster 08-07-2014 10:56 PM
I'll still running the hp 500 heads on my set up. With 93 Octane
the deep 08-07-2014 11:34 PM
Got to check and see if these are what I need . Blown 509 maybe 540 in the works .
tpabayflyer 08-08-2014 12:14 PM
If you go 509 sunrocket has a set of h-Beam rods for sale that will be a perfect match for these pistons..... I don't know about 4.25" cranks but the compression distance would probably not work with these pistons in a 540.....
tpabayflyer 08-08-2014 12:21 PM
Stock compression you should be fine with 87 octane?? If you go 10.25-1 C/R with iron heads I think you are asking for problems...... Aluminum heads should be OK. I run 34* timing in mine and even overheated it up to 235/240* and it did not knock even once.... It was at idle of course and I do have aluminum exhaust and Intake that really draws the heat from the motor fast...... I would not go that high on compression unless you use aluminum heads......
the deep 08-08-2014 01:30 PM
Waiting for a reply from RMBuilder . Not sure what would be my ideal cr . I'll let you know when I know .
tpabayflyer 08-08-2014 01:58 PM
OK looks like pistons are sold to a crazy man building up a mean 509 with a 3.3L Whipple supercharged! Glad I could be part of the build! TBF
