Comp Cams 911-16 Spring set >
Old 08-19-2014 | 07:59 AM
Default Comp Cams 911-16 Spring set
Hello Guys,
I have a set of used Comp Cams 911-16 springs with 8 hours on them; these were used in a 454 MAG with an upgraded flat tappet cam before I switched to a full roller setup.
COMP Cams#911-16
Single Outer Valve Springs
Rate: 373 lbs
1.110'' ID, 1.524'' OD
Seat Load: 122 lbs at 1.900''
Open Load: 309 lbs at 1.400''
Coil Bind Height: 1.200''
With Damper
16/pkg
I can send pics if anyone is interested.
$30 shipped.
Ken barkhouse is offline
