-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   ISKY Camshaft 396284/.294 (https://www.offshoreonly.com/forums/swap-shop/318888-isky-camshaft-396284-294-a.html)
inspector747 10-08-2014 01:34 PM
Camshaft is in great condition (Needs to be dry exhaust), Here are the specs
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 3,000-7,000
Intake Duration at 050 inch Lift: 238
Exhaust Duration at 050 inch Lift: 248
Duration at 050 inch Lift: 238 int./248 exh.
Advertised Intake Duration: 284
Advertised Exhaust Duration: 294
Advertised Duration: 284 int./294 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.578 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.608 in.
Valve Lift with Factory Rocker Arm Ratio: 0.578 int./0.608 exh.
Lobe Separation (degrees): 110
Computer-Controlled Compatible: No
Grind Number: RR-284/294
Valve Springs Required: Yes
Camshaft Manufacturers Description: High performance use/bracket racing; off-shore marine with I/O drive. Lopey idle. 2,500 stall. Up to 11:1 compression. 3.90-4.10 axle ratio. Up to 780 cfm carb.
http://i129.photobucket.com/albums/p...ps916a0059.jpg
http://i129.photobucket.com/albums/p...ps8615f52d.jpg
Asking $250.00 +Ride
Borgie 10-09-2014 09:37 AM
Bump
inspector747 10-10-2014 07:21 AM
Ttt
inspector747 10-11-2014 11:58 AM
Ttt
inspector747 10-13-2014 11:32 AM
Ttt
inspector747 10-25-2014 10:13 AM
Ttt
pantera 30 10-25-2014 04:20 PM
what size block was this cam in
inspector747 10-25-2014 07:11 PM
502
