Mercury racing 525 efi fuel injection
Thanks a bunch KW, as soon as I get the complete parts list I will let you know
525 efi does not have a distributer .Uses a cam position sensor ..Mercury List is around 175.It looks like in pictures the coils are on the electrical plate...Not that u care
It is a ACDelco 213-350 GM original equipment engine oil pump driveshaft with cam position sensor.
they sell on amazon.com for 197.09 with free shipping. the ones thru merc. are over 800. learned this the hard way.
your right its not a true dist. it is a oil pump drive cam position sensor! The newer ones have a oil pump drive that bolt's into the lifter galley, they moved the cam sensor up under the timing cover onto the cam gear. as far as coil packs they had two mounting places, it all depends on witch wire harness you have. I know this because I built a pair of 565cu in. engines that uses the merc. 525 efi platform so yes I do care.
ok thread hijack.possibly a stupid question.i have a gen6 454 mag.can i put this set up on top of my motor and use my old distributor/ign?or is it controlled by the 525 ecu?i ask because if i can make it work i would be interested in one of them.
