SBC OEM Hyd Roller Conversion Kit >
Old 12-14-2014 | 08:32 AM
Default SBC OEM Hyd Roller Conversion Kit
This is a used set of GM LS7 hyd roller lifters, GM lifter retainers, GM guide hold down.
GM # 12499225. Originally used on the LS7 engines, these lifters are now replacement for all LSX engines. These were used on a 355 motor I threw together for a spare. They have engine stand break in time on them only.
$50 plus ride.
Ryan00TJ is offline
Old 12-23-2014 | 10:41 AM
Ttt
Ryan00TJ is offline
Old 12-23-2014 | 10:52 AM
SB
Wow ! What is wrong with the small block guys ? This is a deal !!!!
SB is offline
Old 12-24-2014 | 02:19 PM
Sonic30ss's Avatar
Will these work in older non roller block?
Sonic30ss is offline
Old 12-24-2014 | 02:24 PM
SB
No, however, seeing your boat is an 87, your blocks may be like other 86/87+ and be set up for rollers, but using flat tappets from the factory. In other words, many 86/87+ engines came from the factory with flat tappet cams installed in 'roller' blocks.
SB is offline
Old 12-24-2014 | 03:02 PM
SB is correct. Might be worth pulling the intake to find out.
SB, Have a Wonderful Christmas!
Ryan00TJ is offline
Old 12-26-2014 | 09:17 AM
You could probably just pull a valve cover and look down through too, easier than pulling intake
Mr Maine is offline
Old 12-26-2014 | 09:46 AM
Will these work in a Vortec roller block??
Jonesyfxr is offline
Old 12-26-2014 | 10:12 AM
donzi matt's Avatar
If you have access to an inspection camera you can just pull the distributor and go in to look at the intake valley. What you want to see is holes drilled and tapped in three bosses in the center of the valley for the retaining spider.
donzi matt is offline
Old 12-26-2014 | 10:45 AM
Yes
Ryan00TJ is offline
