gen 5 502 block crank pistons
I have a gen 5 502 block crank and pistons .has been bored .030 a while back .motor was balanced .. long story short the top end of motor had recently been done .and the wrong intake gaskets were used .motor ran lean and burned 3 pistons .1 cyl has some small scores but will clean up no problem with 030 again
block was a fresh water block its entire life never in salt and very clean
I did run a hone in the 1 bad cyl so you can see the small spots im referring to
$1000 for the block and rotating assembly .I will ship it alsoon your dime
