-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   bravo hp gimbal assy (https://www.offshoreonly.com/forums/swap-shop/327455-bravo-hp-gimbal-assy.html)
airjunky 07-15-2015 10:29 AM
Yep . You must be one of the ones i have sent pictures to
This is for those with a worn or damaged high performance transom needing parts or std transom wanting to upgrade. I do not have the 3 bushings that go into the gimbal and bell.
I do have a bravo transom assy avail seperatly if you wanted to build a transom off the boat then swap
Mr. Buss 07-15-2015 11:39 AM
I didn't ask for pics, just tryin to clarify for others. I really could use this, but I got no money!!
davva 07-15-2015 03:14 PM
So to clarify,
I have a standard Bravo Transom but i want an HP Transom, Can i buy your parts and transform my standard transom to a HP?
Is this a big modification?
Im a good mecanich but i never dissasembled a transom
airjunky 07-15-2015 04:45 PM
Yes temove your gimbal and bellhousing install this.
The wildcard will be if you can reach the swivel pin nut from inside.
Trojan-man 07-25-2015 12:56 AM
Can you text or email pics of what you got? 281-799-1414 or [email protected]. Thanks !
airjunky 07-26-2015 05:26 PM
Still on the block . Needs to go to a good home .Swivel pin opening tight , with pics to verify . No this isnt a complete transom assy for 650 but it is fresh hp early cast 1997 gimbal ring and bell ,side pins no bushings or seals mint threads . Help me fund finishing my 540 build while getting a great deal on a hp gimbal upgrade kit.
