#5 trim rams
Looking for (2) trim rams for #5 drives, pin dia. 7/8"
Anyone? |
I think that's a 3/4 pin 7/8. The 5 should have a 1 inch as far as I was aware.
Originally Posted by Sick Stinger
(Post 4522176)
#5 is 1" pins, if you are 7/8" either you don't have a #5 or gimbal ring is not for a #5.
Found them, thanks.
Originally Posted by rv
(Post 4522289)
If the pin that goes thru the drives case, is 7/8", you have a #4. |
OK, will double check, thanks.
I still need these, turns out wrong PN on what I thought was the assy.
Anyone have a set that are in good working order? They are in fact for a #5 drive. 1" pin is correct. |
| All times are GMT -5. The time now is 12:06 PM. |
