Hydromotive p5 25p
https://cimg0.ibsrv.net/gimg/www.off...444a55a4c.jpeg https://cimg1.ibsrv.net/gimg/www.off...d1863565b.jpeg 5 blade hydro prop,25 pitch, no damage, gonna be to small for new combo. $400 shipped call or text 386-837-7035 |
Will the prop fit 1.25 prop shaft?
I believe it will fit both. If you swap the hubs |
im pretty sure hydros are a fixed hub.. looks like it from the pix as well.
Second pic shows the hub removed |
It is interchangeable from big to small. I currently have the small hub for it. |
so if you look at the back side of the prop that hole determines what size shaft it will accept. unless the inner sleeve is removable it is a fixed hub.
Like i said it is interchangable.....https://cimg2.ibsrv.net/gimg/www.off...74a953540.jpeg |
Freek, all you need is a new 1.25 Merc Hub. The newer a Hydromotive props use the Merc hubs.
Bnbz, how did it run on your 280 Velocity? What engine? padraig |
Originally Posted by Padraig
(Post 4630624)
| All times are GMT -5. The time now is 09:30 AM. |
