Set of 540s
https://cimg3.ibsrv.net/gimg/www.off...16fcf93f2.jpeg
Pair of 540 Merlin block motors, originally had whipples on them. Sold the whipples bought intakes and carbs to make complete again. merlin heads dart intakes dominator carb eagle Lower ends Roller cams and rockers 12 qts pan MSD dist and box will have matching cross overs and T housings also. lower crank pulleys will be included. come as seen. have video of the. Running. 13k for the pair. hour meter read 55. boat was turn key runner when pulled. |
https://cimg0.ibsrv.net/gimg/www.off...1554b8512.jpeg https://cimg1.ibsrv.net/gimg/www.off...d9a4d1cfc.jpeg https://cimg3.ibsrv.net/gimg/www.off...053ef234e.jpeg https://cimg4.ibsrv.net/gimg/www.off...6aa803f6d.jpeg https://cimg2.ibsrv.net/gimg/www.off...3c9d6080b.jpeg Didn’t load the 1st time. also have 2 sets of CMI split tubes and tails or staggered Stellings |
So they've been run and tuned since you pulled the whipples and put intakes on ?? any videos of them running ?
If you notice there are no bolts in the intake. No where did I state I installed them and ran them. I have videos of motors in boat. if you would like I’m happy to install, and dyno tune then. Will have video on the dyno and sheets to accompany. Last set I did the same with, sold blower and installed intakes and carbs they made 700. Not saying these will or same set up but they will make decent power due to size alone. I can give you my address for a deposit |
Originally Posted by Sick Stinger
(Post 4712867)
It would show you they were pulled running, as I stated. This would verify it. I believe that’s what it could do for you. |
Cmi split tubes
Do you still have these pipes or any other tube style hheaders for bravo
1 set of bravo dry EMI pipes left
I am looking for two complete big blocks. you still have 540s. tom 3522836385 tex me
How much for the EMI pipes? text me 7138344686
| All times are GMT -5. The time now is 03:20 PM. |
