BB hydraulic roller cams
Gen 6 502 stock 211 230-510 540 $50
Crane Mark 4 #139621 iron dist gear 214 222-553 576 110 lobe sep. $250 Marine Kinetics/cam motion Mark 4 iron by dist gear 236 244-595 612 114 love sep. $250 Paypal & shipping avail. Text 914-262-1898 NJ https://cimg5.ibsrv.net/gimg/www.off...0f7f1f3d9.jpeg https://cimg9.ibsrv.net/gimg/www.off...59cd95f47.jpeg https://cimg6.ibsrv.net/gimg/www.off...445c4ae7d.jpeg https://cimg0.ibsrv.net/gimg/www.off...d2cf6f16c.jpeg https://cimg1.ibsrv.net/gimg/www.off...13edbcf54.jpeg |
Cam
I'm building a mark 4 454 30 over, roller motor with a wieand 177 blower on it would any of these Benifit me to buy one with my build
You need wide lobe separation with a supercharger so the marine kinetics might be a good fit. I believe it’s very similar to Merc 525 cam. What else can you tell me about the engine. Heads, compression ratio, amount of boost and rpm range would be helpful.
Cams
Engine is still at machine shop getting block decked but boost the blower is set for 5-7lbs of boost heads are stock mark 4 big square port heads I had cleaned true up resealed and some port n polish work done pretty much I'm shooting for a build like the 525sc but I still need a cam valve springs and depending on how much gets taken off block push rods
Cams
It's is .30 over sealed power pistons, rpm wise it would do 4800 to 5k before
I think the specs are right where you need to be. It’s marine kinetics cam (Rmbuilder) here on oso. You could message him and see what he thinks.
| All times are GMT -5. The time now is 04:03 PM. |
