-   Swap Shop (https://www.offshoreonly.com/forums/swap-shop-253/)
-   -   Stelling box (https://www.offshoreonly.com/forums/swap-shop/378625-stelling-box.html)
NYBoat82 03-11-2023 05:02 PM
Stelling box
Have two stelling boxes with hp gimbals for sale $2800 each
NYBoat82 03-12-2023 09:33 AM
https://cimg9.ibsrv.net/gimg/www.off...5a96b766f.jpeg
https://cimg0.ibsrv.net/gimg/www.off...ce8255dcc.jpeg
https://cimg1.ibsrv.net/gimg/www.off...f40aa8b04.jpeg
TylerG 03-12-2023 06:19 PM
Do you have the inner transom plates for these or the drive shafts? Would you separate the transom assembly and one box?
BBYSTWY 03-13-2023 05:33 AM
I believe that stellings don't require a long shaft..I think they have a stub shaft that goes to the engine and you use the standard length shaft that goes into a coupling inside the box....I think...
I have a couple questions....
Where are you located
Do you have the side covers for the big holes in the sides
Am I accurate in my thinking above with the stelling boxes?
sutphen 30 03-13-2023 06:41 AM
you have it right,,but imco does make a long shaft too.thats How I set up my boat,,the imco shaft.
BBYSTWY 03-13-2023 06:46 AM
Isn't the idea of the stelling to allow you to run it higher without the shaft binding? I thought I remember reading somewhere there was a reason they designed it that way but can't remember?
Good to know that you can gut the box and run an imco shaft instead! Didn't know you could do that!
BBYSTWY 03-13-2023 06:54 AM
Also....anyone have a pic or info on where and how to mount steering arms on these? Imcos have holes for brackets I believe but don't see anything on these?
Sick Stinger 03-13-2023 09:59 AM
these run a small drive shaft and engine coupler thats to the flywheel you bolt the drive shaft to
Sut30 is right though, best to tun the imco torque shaft
NYBoat82 03-13-2023 10:44 AM
Have these listed for a friend, will go up tomorrow and take pictures of everything it comes with
sutphen 30 03-13-2023 07:28 PM
no mount option on the boxes,,steering rams have to go to the transom.
