The B.S. Thread >
The B.S. Thread
The B.S. Thread
Old 10-24-2007 | 03:01 PM
  #12511
I hate to break up the love fest going on here, but I found out the problem with my starboard engine. CLPBS pulled the motor and found the #8 piston fried and a bent valve. The #8 spark plug was broken and he thinks it wasn't firing and might have sucked up some water causing a reversion problem. Also some signs of detonation on the piston. So time for top end rebuild with valve job and all the injectors going in for a flow test. Glad we caught it before it let loose. This was the same problem that the port engine had even the same cylinder, the only difference is I have to pay for this repair.
gerritm is offline
Old 10-24-2007 | 03:11 PM
  #12512
[QUOTE=txlefty;2316042]FOX TROT VECTOR CHARLIE....WE'RE TAKING ON EMENY FIRE...ALL HELLS BREAKING LOOSE!!!!! SEND IN ALL THE 10YR OLDS YOU CAN SPARE!!!!!! WE'RE GOING DOWN!!!!! BREAKER ONER NINER KIM HAUL AZZ!!!! THE 8TH GRADERS ARE KICKING OUR AZZ!!!!!QUOTE]
Nice job with the teeth
I will put in a good word for you with the kids. I know that is the age you like'em....
Hey when you go meet with my accountant will you not jerk him around like you do the guys at Konrad. His time is limited and he doesn't give a chit about what you are "going" to do/ will never happen.
Thanks.
joew. is offline
Old 10-24-2007 | 03:14 PM
  #12513
Well atleast it isn't on the bottom end. If you want I can have Lefty's guy go down and fix it for $48.99 and a steak. Let me know????
joew. is offline
Old 10-24-2007 | 03:20 PM
  #12514
$48.99 and a steak, such a deal.
gerritm is offline
Old 10-24-2007 | 03:22 PM
  #12515
He will even fix it in your garage
joew. is offline
Old 10-24-2007 | 03:25 PM
  #12516
The problem will be the $25K for the bigger garage.
gerritm is offline
Old 10-24-2007 | 03:30 PM
  #12517
I am joking... I would drive down there and hit you in the head w/ a hammer if you let that guy near your boats
joew. is offline
  #12518
tomtbone1993's Avatar
before Lefty found Chris we use to have a mechanic work on boats for left over junk.......those where the days. If you like we can send jeff00001gayman down to give CLPBS a proper second opion
tomtbone1993 is offline
Old 10-24-2007 | 03:36 PM
  #12519
hey chris was referred to me....i didn't find him. What's been happening to Hodges? I haven't seen him around much since Jeff cussed him that night..
we need to find us someone who knows their $hit!
txlefty is offline
Old 10-24-2007 | 03:45 PM
  #12520
check out what WStultz has been doing....
http://www.offshoreonly.com/forums/s...d.php?t=171457
