The B.S. Thread >
The B.S. Thread
The B.S. Thread
Old 12-14-2007 | 05:27 PM
  #14161
tomtbone1993's Avatar
Originally Posted by BY U BOY
Tman thats the whole thing i don't want to remove t i just want to fix it.
please explain to me how hard it is to remove your single hampster from its cage????
is it lack of room???
fix the gimble correctly.....
tomtbone1993 is offline
Old 12-14-2007 | 05:29 PM
  #14162
sarahcooper, how have you been???? nice of you to join us
Please tell us now BY U Boy will never own a boat after you two tie the knot
Old 12-14-2007 | 06:45 PM
  #14163
bigandy's Avatar
what is the plan boys???
bigandy is offline
Old 12-14-2007 | 06:49 PM
  #14164
501 bulc
Old 12-14-2007 | 07:28 PM
  #14165
bigandy's Avatar
501 bulc
REDRUM! REDRUM! REDRUM! REDRUM!
Trivia: what is the name of Sonny's sailboat!?!?
bigandy is offline
Old 12-14-2007 | 08:07 PM
  #14166
Wade
http://cgi.ebay.com/ebaymotors/OLD-R...QQcmdZViewItem
jeff1000man is offline
Old 12-14-2007 | 09:29 PM
  #14167
BY U BOY's Avatar
The engine is easy to remove but i have no place to do it or store it
Please tell me how this method is not correct? Looks like plenty of people have used this method and are happy with it.
sounds like i can fix it correctly without removing the engine.
BY U BOY is offline
Old 12-15-2007 | 08:07 AM
  #14168
Yes you can fix it that way. I have the mercruiser manual and it also says you can drill a big hole in the side of it, then thread the hole, then screw in a plug when you are done. Which part is loose, the bolt that tightens your steering tiller, or the big nut that tightens the gimbal ring that is located above the tiller?
Trojan-man is offline
Old 12-15-2007 | 08:08 AM
  #14169
you don't have to remove the engine, you just remove the drive and the transom assembly, probably alot more work than just cutting a hole and tightening a nut
Old 12-15-2007 | 09:19 AM
  #14170
BY U BOY's Avatar
the hole that the swivel pin goes into on the gimble is worn out i have a lot of side to side play in the drive.
BY U BOY is offline
