The B.S. Thread
can't you just say sewage hit all the walls in your house, won't they call it ruined and give you enough to just about rebuild your whole house.... at least a good remodel???
hey when I bought my house I had a water leak from the roof, I replaced the roof and fixed the leak but as a result of the leak the header on the garage door is sagging, and the wall to the side of the garage door is rotted/rotting, if I make a claim will homeowners ins cover that?
I am fighting that battle right now.
you fixed the leak, but you never fixed the damage FROM the leak, so your wood and wall rotted. That stuff doesn't just dry up and go away. You should have made a claim for it back then. Answer. Probably not, unless you have an HO- B policy which covers lack of maintenance. Pretty rare policy, but some of them are still out there.
Is he handling your pack out and storage? If you want to make up your deductible on them, Build an invoice that charges by the hour to clean all of your junk and per box to pack it all up and store it for the time that he is working and do it yourself. Have Joew sell you some boxes. Put the stuff at your boat storage and charge them the rack rate for the building.
It will be thousands of dollars when you are done adding ti all up
You probably all ready knew that trick though.
It might be covered under your current policy if you still had the leak, but the evedence that it was a leak was hidden from you until recently when you accidentally ran across it.
Not likely though.
best buy muther fu(kers....http://www.youtube.com/watch?v=HvKp9XxoEsQ
Did you guys notice how Lefty ran around to the other side of the bar when the chit started going down and how Colter ran FROM the other side of the bar.
