The B.S. Thread >
The B.S. Thread
The B.S. Thread
Old 03-18-2009 | 01:44 AM
  #27651
Ya bunch of goofy's
jeff1000man is offline
Old 03-18-2009 | 05:56 AM
  #27652
Originally Posted by spk1
What are the dock restrictions behind your house,, lol Id just ground it back there and then you would have one hell of a property!
Good idea.
Old 03-18-2009 | 12:10 PM
  #27653
tomtbone1993's Avatar
Good idea.
did you make this post to let everyone know you where up at 6:00AM??
tomtbone1993 is offline
Old 03-18-2009 | 12:42 PM
  #27654
What do you guys think about this for my center engine?
http://www.cpperformance.com/detail.aspx?ID=9038
I wonder if it can be welded on the outside with the tips still in the boat, or if I could get them welded onto the tails before they meet the tips.
I don't want to remove the tips if all possible.
Old 03-18-2009 | 02:24 PM
  #27655
wstultz's Avatar
Social Distortion
I think you would blow torch that "anti-burn rubber" evertime you took it out and it was running lean. You welding and brazing bill would be much higher than $39.99
wstultz is offline
Old 03-18-2009 | 02:44 PM
  #27656
it has to go through 6ft of pipe before it gets to the flapper.
Old 03-18-2009 | 03:06 PM
  #27657
i have 4 brand new rex marine tips for the rear engines. I just have a problem on steep ramps with water comming up the rear tails. I told CMI when i ordered the tips I would need internal flappers. They said I would be fine...guess what they were wrong..I just want to cure this little issue since I currently have all the headers off. I think I would be better off welding them to the end of the tails.
Old 03-18-2009 | 04:25 PM
  #27658
wstultz's Avatar
Social Distortion
I got some nice tips made from Stainless marine with metal flappers with rubber edges made. Nice hardware and all four of them cost me like $100 if I remember correctly. Maybe you can send those guys your tips and they can add their internal flappers.
wstultz is offline
Old 03-18-2009 | 04:44 PM
  #27659
I can't get the phuckin tips out....I don't want to pull out my back.
keep in mind these are the ones at the bottom on the outside of the rear engines...they are a muther phucker to get to
Old 03-18-2009 | 04:45 PM
  #27660
I bought these whenever I blew mine out. No welding and took me about five minutes to install.
http://www.danamarineproducts.com/ExhaustFlappers.htm
mba1620 is offline
