-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   big tire/wheel upgrade for dually (https://www.offshoreonly.com/forums/trucks-trailers-transportation/102128-big-tire-wheel-upgrade-dually.html)
JPD Motorsports 05-16-2005 02:08 PM
Re: big tire/wheel upgrade for dually
2112 I have seen some f350's with a short bed on a dually from the factory, dont know what wheel base it was crewcab 4x4 short. Hopefully one with more knowledge will pop in.
2112 05-16-2005 11:48 PM
1 Attachment(s)
This is my current tow rig. I'm wanting this in a dually.
offshoredrillin 05-17-2005 05:11 AM
thats sweet, my buddy that had the raised CCdually with the 44's on it is dropping it back downa and selling it. It's black 7.3, already has the banks kit and exhaust on it. I think its an 03 not sure though...if you're interested let me know...Rob
either that or you can put a dually rear under yours and get the fenders, it would be unique for sure:)
Sydwayz 05-17-2005 08:00 AM
2112, that's a nice truck. I'd convert it to a dually.
2112 05-17-2005 10:36 AM
It is my understanding that converting to a dually requires both the front and rear axles to be swapped as well as a few other modifications to the frame. That doesn't bother me but there comes a point where it doesn't make economic sense.
Offshore... I hoping to have a supercab instead of a crewcab. I really like the short length of a supercab and shortbox. This truck is an 04 and the 6.0 is way more potent thatn the 7.3 I had in my 01. Just need to keep it up in the RPM band to use it. One other advantage to the dually is the available 4.33 gear ratio....perfect for the 6.0.
offshoredrillin 05-17-2005 12:12 PM
From my understanding, the only diff in the front axle is the hubs for a dually. My buddy took his springs and everything from his dually when he raised it and put them in his 2500 to give it a beefier suspension. Everything bolted up perfectly.pm Mat Raymond on here he may be able to get all the answeres as he owns a dealership in NC...Rob
JPD Motorsports 05-17-2005 10:32 PM
the 350 to 250 springs will swap then you get the rear end and change out the front hubs to dually stlye or order a set of floats for the front and dual out the rear. I havent seen one in an extra cab(hence) short bed dually around thought, just the crews.
dukenrock 05-23-2005 10:44 PM
Nice ride, how much? Let's see some more pics.
Originally Posted by mcraymond3
Let me know if you want to order a F450. I just got one with air ride suspension and it is pretty cool. I will post pics when I finished getting it dressed.
www.sandersford.com
