4x4 truck or 2x4 truck to pull with????????? >
Old 05-27-2005 | 08:50 AM
Wardey's Avatar
Default Re: 4x4 truck or 2x4 truck to pull with?????????
4X4. I would not own a truck with out it. Not only do you have 4 wheel drive, you also have a low range !!! Dave
Attached Thumbnails 4x4 truck or 2x4 truck to pull with?????????-truck-ramp.jpg
Wardey is offline
Old 05-27-2005 | 12:24 PM
you might be OK with a 4x2 as long as you dont go to unfamiliar places.......went to one ramp where a buddy said i could get in "no problem"......there was a problem .......I coulnt turn around!!......ended up having to back the boat up a steep hill in the dirt from a dead stop........2wd.......dug two holes 6" deep in one second flat......trailer never even moved!!!......dropped it into low range four wheel........didnt turn a tire.......4x4s for me!!! .......doug
Attached Thumbnails 4x4 truck or 2x4 truck to pull with?????????-dsc00139.jpg
pullmytrigger is offline
Old 05-31-2005 | 10:41 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Is it possible to get a 2WD truck that has a low gearing like the 4x4s?
Never had to use 4WD at a ramp before, but HAVE to have the low to back the boat up the driveway. Reg. reverse is pedel to the floor and still no go.
US1 Fountain is offline
Old 06-01-2005 | 05:06 AM
CMG's Avatar
CMG
nope, just lower rear gears
Chris G.
CMG is offline
Old 06-01-2005 | 02:58 PM
Comanche3Six's Avatar
Bang!
Right on point.
Comanche3Six is offline
Old 06-01-2005 | 03:10 PM
Tim G.'s Avatar
Performance Boat Center
Wardy is very right...
Low range not only gives you more power to pull, but it also increases traction, as it gets rid of peaky power...like on a turbo diesel.......
I tried very hard to bring myself to buy a 2 wheeler..to save some money, but I couldnt... My 4x4 D max is great! I haven't had it in low range yet...
This is my work truck. The load here is 10,000lb. The truck has a 5.4 gas (POS)... It will NOT pull the boat up a steep ramp without Low Range... It rarely spins the tires, even in 2wd, but the motor just doesn't have the azz.....
Given that your boat isn't real heavy, You could go with a 2wd as long as you order a posi or locker... You also have to keep your head screwed on straight and just don't spin the tires.....
Going diesel???
Attached Thumbnails 4x4 truck or 2x4 truck to pull with?????????-chevy-sm.jpg   4x4 truck or 2x4 truck to pull with?????????-truck-angler-f.jpg
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 06-01-2005 | 05:47 PM
dykstra's Avatar
4X4
dykstra is offline
nova26
41
07-07-2008 06:10 PM
paintkahuna
0
01-31-2008 04:52 PM
Shorgasm
11-28-2003 10:50 PM
Wally
09-23-2003 03:43 PM
puder
06-04-2002 02:32 PM
