Aluminium Trailer sparkle
Old 01-01-2006 | 11:47 PM
GoCiggie31's Avatar
From: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
Default Re: Aluminium Trailer sparkle
all great advise, thanks
docmanrich37;was all your labour manual or did you use a drill, orbitor, handbuffer?
A Very nice job!
GoCiggie31 is offline
Old 01-02-2006 | 07:23 AM
AKA NoMoBoatin
A Very nice job!
I used a mini 3" d a.Plans are to polish the outside and top of trailer and then 2 coats of wax on it and thats about it.sounds easy.
docmanrich37 is offline
Old 01-02-2006 | 09:56 AM
itilldo's Avatar
This may sound funny but has any one tried Easy Off oven cleaner. I'm a Welding Engineer and a colleague of mine who over see's the welding of the Ford GT frames (100 % aluminum) has to macro etches the weld samples. He uses Easy Off oven cleaner and he states that it makes the samples shine. It might be worth a shot at doing it under the bottom side just to see if it works. Spray it on and let sit for a bit, then wipe it off.
itilldo is offline
Old 01-02-2006 | 05:59 PM
Chuck's Avatar
Once you polish it there is a spray product from alcoa aluminum that will make that chrome look last alot longer. A great deal of work for a boat trailer, but you can't make the scene if your rides not clean . Do a search under yahoo for alcoa products. Good Luck
Chuck is offline
Old 01-02-2006 | 08:24 PM
t500hps's Avatar
21 and 42 footers
BS!!! Your just gonna write a check
t500hps is offline
Old 01-02-2006 | 08:25 PM
Rocky Dell's Avatar
Auto Sales & Leasing
I used to use Magic Mix Aluminum Brightner on my Kenworth Tri-Axles. Used them on the Alcoa Aluminum Wheels and Dump Bodies. Worked pretty good.
http://www.valco-cp.com/Magic%20Mix.htm
Rocky Dell is offline
Old 01-02-2006 | 08:29 PM
CBR's Avatar
CBR
www.hyperfishing.com
Yep, paint the new trailer with clear coat. Solves most problems I would think. Clear coated the bottom of our new WS6 car in 1996, still looks new!
CBR is offline
Old 01-02-2006 | 08:37 PM
AKA NoMoBoatin
I'm broke after my bar tab from sat. night.lol
Old 01-02-2006 | 09:07 PM
t500hps's Avatar
21 and 42 footers
Yeah, me too
t500hps is offline
Old 01-03-2006 | 06:19 AM
Registered User
http://www.aircraftfinishing.com/evershield.htm
It ain't cheap but it's amazing stuff
Chris Sunkin is offline
