-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   What Tires will fit a 2003 3500 Dually ? Need Bigger (https://www.offshoreonly.com/forums/trucks-trailers-transportation/115453-what-tires-will-fit-2003-3500-dually-need-bigger.html)
Ike 11-02-2005 07:56 PM
Re: What Tires will fit a 2003 3500 Dually ? Need Bigger
1 Attachment(s)
Here it is.
Byrdman 11-02-2005 08:53 PM
2 Attachment(s)
here is a hot one i like. :cool:
dukenrock 11-03-2005 10:56 AM
1 Attachment(s)
'04 3500 with 19.5 Ricksons...
Strip Poker 388 11-03-2005 12:58 PM
Originally Posted by Ike
Rob, I put 285/75/16 goodyear ats "D's" on my 02 chevy dually with the alcoa's,up front i turned the torsion bars up 3.5 turns and in the rear i had arp make me longer studs and had 2'' spacers made. I towed my 41 apache for two years and 32,000 miles with no problems at all and it looked perfect filled up the wheel wells and still was inside the fenders and no rubbing. Ike
Ike about How much did the studs and spacers cost????
I really didn't want to get into buying spacers and studs.
I guessing the 235/85/16 is as big as will fit with out rubbing?...The bad thing about it the 235's you probably want be able to tell much difference in looks:( :(
Thanks for the replys :D
Rob :drink:
Bryan Rose 11-03-2005 04:56 PM
Rob :drink:
Subtle look difference... not in a SoCal way... but much better...
Bryan
CAVelocity 11-03-2005 07:47 PM
I wasn't happy with the 235's.... it just looks like it should have from the factory.
Ike 11-04-2005 07:16 AM
Rob the studs hurt bad, over $550.00 but i had two extra made. if you want to borrow one and try to have them made or matched up somewhere else pm me, the spacers i had made by a local machine shop for $80.00 Ike
Strip Poker 388 11-05-2005 01:37 PM
I saw on another site that makes the spacers with the studs built in 2 inch spacer. I wonder how much they are$$ and do they put the tire out side the wheel well lip???????
Rob
offshoredrillin 11-06-2005 01:57 AM
Rob,
go to www.brentzwheels.com he is a freind of mine, I intro'd Sean to him at the SEMA show...I love my 19.5's on my 01 GMC.
Strip Poker 388 11-15-2005 05:12 PM
Ike a found a place that sells the spacer conversion kit for 140 each there 2 inch and comes with the studs.
Did you have to have your speedo reclaibrated at the dealer ship????
Rob
:D
