can a Jeep pull a 10 meter fountain >
Old 03-13-2006 | 11:31 PM
  #31
Outdrive1's Avatar
Masher touches my
Default Re: can a Jeep pull a 10 meter fountain
I tow my 30'er with a diesel Excursion and I'm terrified of loosing a tire or towing any farther than LHC (200 plus miles). I've been contemplating getting a dually for about a year now. No way would I tow anything heavier with my truck even though I know it's capable of it. The safety of my family comes first. Dual wheels, low center of gravity, properly inflated tires, working trailer brakes, that's what you need for a twin engine 35'er IMO.
Do you really expect someone to come on here and say it would be ok to tow that boat with a little half ton Jeep?
Outdrive1 is offline
Old 03-14-2006 | 01:28 AM
  #32
jordy's Avatar
Originally Posted by Chris288
Pulling my little old 288 single with a f-150 is on the edge IMO, I wouldn't even consider pulling anything bigger,, nevermind a 30 footer w/ twins and a jeep !!
Just off the top of my head, but a 10 meter Fountain is just shy of 33' although, by the time you figure in the beak and integrated swim step you are much closer to the 25' mark, but I still wouldn't do anything but drive down to a wet slip in a Jeep if that boat was invloved.
jordy is offline
Old 03-14-2006 | 05:48 PM
  #33
bouyhunter's Avatar
Originally Posted by Jesse James
no
Can you expand on that??
Oh never mind, it's not necessary.
bouyhunter is offline
Old 03-14-2006 | 06:49 PM
  #34
Originally Posted by Sydwayz
Different folks have different opinons of need.
I have an F-350 PSD Dually and will still be using my WD setup to tow my 12K lbs. boat/trailer. I set it up originally to tow properly and legally with my 2500 Avalanche, rated to 12K lbs., which in my configuration, did not require a WD setup. The difference in handling while towing is quite noticeable.
Duallys are ok....as i have stated for months.....it is the peeps that use this stuff on single wheel vehicles that are really over the limits....I do not care what all the idiot manufactures are saying.....it is what goes happens on the street that counts...that avalanche is a turd for towing....which is why you have a dually....at least you made the move..
Byrdman is offline
Old 03-14-2006 | 07:28 PM
  #35
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I bought a dually because I really wanted a black dually.
I love my dually so far, and just went to the truck-goody place today, but I miss my Avalanche already.
Sydwayz is offline
Old 03-14-2006 | 08:33 PM
  #36
scottc's Avatar
Most class lll and lV hitches are only rated for 6-10 k weight carrying. If you step up to a class V you might see 12k wc. Most balls and ball mounts ar only rated for 10k. So with that under you hat now, Brian is one of the few that IS doing it right with the wd system. Now, taken into count there is a very large safety margin on stuff like that you can get away with some crazy tows. No the Jeep is pass it's ratings but it will work at the ramp. On the road I would think real hard about it.
I launched a 402 Formula with a F150 for most of the summer. It was not an easy job but it worked. Now I have a little larger truck to move it around. And feel real safe. But here again the draw bar and ball are only rated for 10-12k. I have almost 1800lbs of tounge weight. Is it safe? Am I comfortable with?
Attached Thumbnails can a Jeep pull a 10 meter fountain-formula-008-medium-.jpg   can a Jeep pull a 10 meter fountain-truck-001-medium-.jpg
scottc is offline
Old 03-19-2006 | 08:25 AM
  #37
Strip Poker 388's Avatar
Rob
I coundnt belive it didnt squat and much as it did .
Attached Thumbnails can a Jeep pull a 10 meter fountain-chevelle-eng-element-bryant-eng-051.jpg   can a Jeep pull a 10 meter fountain-chevelle-eng-element-bryant-eng-054.jpg   can a Jeep pull a 10 meter fountain-chevelle-eng-element-bryant-eng-045.jpg
Strip Poker 388 is offline
Old 03-19-2006 | 12:42 PM
  #38
Convert to a new style pintle or something....it is something better than a pos ball????.....nice truck for pulling...you will be happy and see what it is supposed to be like!!
Byrdman is offline
Old 03-19-2006 | 12:50 PM
  #39
birdog's Avatar
You can buy 2 5/16 balls rated at 30 k
birdog is offline
Old 03-22-2006 | 03:49 PM
  #40
Does the f150 make a clunking sound as the transmission shifts into gear now? hehe
spk1 is offline
