4X4 Use on the launch ramp
I almost miss my old F250 with manual locking hubs, was able to put transfer case in low and not have the front end bind up (new has auto locking) at top of ramp when making tight turn. If tires ever spun I would then lock the hubs.
Then again now being boatless I don't have any trouble at all
Chris G.
Chris G.
Originally Posted by scottc
There is a kit to convert the hubs to manual hubs........the best thing out there is being able to select the hubs being locked or not.......................
Chris G.
Chris G.
Originally Posted by sign4boat
I use it all the time, but heres a couple pics. of the ramp i use.
Chris G.
Chris G.
Registered User
Originally Posted by Boomer 880
Also, I am trying to determine if the F550 is needed. I have a 40 Hustler and may move up, but not 100% sure. Been looking at a few 450s and 350s. I am worried that I will be near 15K on the F350 tow rating... not worried that the truck can't handle the weight, but liability issues if I am over 15K.
PS, I know, go to a scale and weigh it
Liability is a big one that many overlook. Keeping yourself alive is even bigger. While the light-duty pickup will pull these monsters, once you find yourself in a scrape, you'll have the best results with the biggest truck you can buy. I rolled a 38TG with an under-limit dually. Wasn't fun. The Apache gets tugged by an FL70. I've done a couple of quick maneuvers and even got about 3' off the berm into the grass to avoid a left-of-center. Yanked it right back up with zero fuss. You can hardly feel it back there. The driving is alot more relaxed too. None of this white-knuckle crap anymore. Steep, wet, greasy ramps are something I avoid with it for obvious reasons.
I bought the FL70 for a third of what a new 550 costs. It pulls the boat and serves double-duty anytime I need to move anything bigger than will fit in a pickup. 16' flat bed.
I don't normally use it. I look at the ramp and see if the water level is low...if it is, it's usually "slimy" because the water is usually covering it. I probably use it half the time. It's good to have 4x4 when you need it
I use 4 low all the time just think it puts less stress on the truck. I had manual transmissions before and figured 4 low was easier on the clutches. i didn't figure this out until the third clutch though. Usually pull pretty big boats out at the ramps, and when the boat is not all the way on the trailer it tends to lift the rear wheels off the ground. Nice having the front wheels locked when I'm on the trailer operating the winch.
I use it everytime. It only takes a second to switch and the truck doesn't even know the boat is back there in 4L.
I also use 4wd, when launching, that way I don't have to worry about the front tires slipping.
