Trailer Ball installation, torque 400 ft lbs?? >
Old 03-23-2006 | 11:04 AM
Default Re: Trailer Ball installation, torque 400 ft lbs??
Originally Posted by miamioffshore
I have a weight distributing trailer hitch i'm installing. To put on the trailer ball the mounting nut needs 400 ft. lbs of torque. Aside from that I can't get the ball to stop spinning when I try to crank down on the nut. Thus I can't get it any tighter as the ball spins on top. I'm thinking I need a very powerful impact wrench to get this thing started (and get 400 ft. lbs of torque) Any suggestions or am I on the right track? Also any suggestions on who would have an impact wrench that powerful? I stopped by a couple automotive shops but they didn't have anything near that?
Thanks,
M
Hey Miami, have you pulled your boat with that yet? I just wanted to hear another opinion... I just got back mine from having hitch and equalizer bars put on, similar to the ones on campers...man.. does it ever pull good. Smooth ride and not "jolty", much softer ride. How much are you going to have invested in that system. I paid $400 for mine and they set it all up and made the necessary adjustments.
cherrycobalt262 is offline
Old 03-23-2006 | 11:39 AM
miamioffshore's Avatar
Haven't yet, picking it up on Saturday. I'll let you know. I went with a Blue Ox 1500 tongue weight, 15000 weight carrying, its about 1000 more than I needed, but I like it that way. I can tell you from putting it together it is seriously heavy duty, the shank+trunnion+spring arms weigh a total of 110lbs! , and once again I like it that way. The blue ox also has sway control adjustment built in to the spring arms. I will post a full report on the results when I return.
miamioffshore is offline
Old 03-23-2006 | 12:10 PM
Semper Fi's Avatar
If you can, weld the nut on, then it will never lossen or get stolen. I did that after some schmuk stole the ball (not my hitch) off my truck.
Semper Fi is offline
Old 03-23-2006 | 02:24 PM
Registered User
It's a brand new, everything, the whole setup.
Here's what I ended up doing. Put a towel over the ball so as not to scratch it, clamp with vise grips, turned nut to v. grips hit the shank so it was holding itself in place, cranked on it til i couldn't get it any tighter, then put a 4 foot long breaker bar over my 3/4 socket wrench, cranked on it til i couldn't move it even with the breaker bar, then a friend helped me and we turned it another full revolution.
You're there.
The weld isn't a bad idea. I'd rather throw hitches away every month than have another come off.
I also use a grade 8 bolt instead of a receiver pin and have replaced all the hitch mount hardware with G8's. Never use a thread lube, amti-seize or locking compound on a G8 bolt. Lockwashers and torque wrenches. Welds are good too.
Chris Sunkin is offline
Old 03-23-2006 | 02:50 PM
Friggin' loser, stealing a ball!
Old 03-24-2006 | 06:05 PM
OSO's Avatar
OSO
miami,
I assume you bought the Cafe, what are you pulling it with?
OSO is offline
Old 03-24-2006 | 09:49 PM
Semper Fi's Avatar
After I had it welded, it never got stolen, came losse, or came off. I had alot of boats on that ball hitch.
Put some lubricant/grease on the ball--this will make sure that the trailer and ball hitch don't rub too much to loosen the nut.
iamfaster
7
05-17-2005 11:16 PM
US1 Fountain
6
02-22-2004 04:18 PM
New boater man
11-11-2002 11:01 AM
New boater man
4
10-30-2002 06:50 PM
