2007 Denali XL
Originally Posted by pullmytrigger
Have you actually wieghed your rig at a scale????......The manuals for my boat says it wieghed 5500.....I figured the steel trailer would wiegh 1500......so I figured 7500 with gas.......wrong......wieghed it on a scale.....half tank of gas.....all our chit......ready to go......9500......29 Fever twin.......7000 sounds awfully light for a 32ft boat and a trailer.
26' Sonic specs are 5050 lbs. dry. That's 2230 lbs. of additional weight.
Originally Posted by TwinStepGun
If you don't get a dually get a 2500 HD D-Max. I know Byrd doesn't like that idea, but at least you can use the truck for something other than towing when you aren't boating. I pull the Gun with one and it's alot heavier than the Activator. Plenty of room for passengers, TV's and chit.
The Burban can pull my Apache but it's definetely not meant to do it! I would never think to take it on the Highway or over 65 mph.
Originally Posted by Wobble
2007 Suburban 2500 available with 9700 lbs towing capacity cant find the engine specs.
1/2 ton has the 5.3L
3/4 ton has the 6.0L ONLY (No 8.1L in 2007)
Vortec 5300 V8 (Automatic)
MODEL Max. Trailer Weight (lbs.)1 Required Axle Ratio
Suburban half-ton (2WD) 7,100 3.73
8,100 4.10
Suburban half-ton (4x4) 7,000 3.73
8,000 4.10
Vortec 6000 V8 (Automatic)
Suburban three-quarter-ton (2WD) 7,700 3.73
9,700 4.10
Suburban three-quarter-ton (4x4) 7,500 3.73
9,500 4.10
Maximum trailer weight ratings are calculated assuming a base vehicle, except for any option(s) necessary to achieve the rating, plus driver. The weight of other optional equipment, passengers and cargo will reduce the maximum trailer weight your vehicle can tow. See your Chevy dealer for additional details. NOTES: Trailer tongue weight should be 10 to 15 percent of total loaded trailer weight (up to 1,000 lbs.). Addition of trailer tongue weight cannot cause vehicle weights to exceed Rear Gross Axle Weight Rating (RGAWR) or Gross Vehicle Weight Rating (GVWR). These ratings can be found on the certification label located on the driver door or door frame. For recreational towing restrictions and availability, consult the Owner’s Manual.
So it's not going to be the 6.2 380HP motor available in the Denalli XL
You need a BB (in case of GM) as a minimum to tow with reliability and longevity. Obviously, diesel is preferred, but you there is no way I would want one of these newer SBC motors for a HD tow vehicle.
All of these manufacturers have a delicate balance to maintain. They have to build their vehicles and spec them and rate them to capacities that will sell the vehicles off the showroom floor. They also only HAVE to last as long as the warranty. So, they have to build them as cheaply as possbile, just stong enough to get through the factory included warranty. After that, there is the grey area of extended warranty, which is 50% or more profit to the selling agent. Then, GM, Ford, Dodge, or whomever can start making more money off of (us) when we come looking to replace grenaded parts. Do you think the COB of Ford give a rats ass that I bought a 2000 F-350? Other than the fact that I sold a GM to buy it; nope. The manufacturer cash cow is making profit on new vehicles. Dealers profit most from used vehicles sales and service.
Originally Posted by warbird
What kind of vehicle do you big boys recommend for getting my beverages, sunscreen and towels the 20 yards from the back of my pool lanai down to my boat lift where my Midnight awaits????
However,, if your gonna do that trip often and plan to tow very far you most definitely need one of these..
