Duramax LLY upgrades
Old 05-03-2006 | 12:01 PM
Default Re: Duramax LLY upgrades
what are you trying to accomplish with it a good tow rig or flat out a runner? If a tow rig and want to change settings then a programmer like a quadzilla or edge module will get you there. For exhaust I would highly reccomend the mbrp and for an intake if you want the turbo whistle to be louder look at an intake kit with the metal/aluminum tube with a cold air box surrounding the surround. if no turbo whistle is in the plans then get a green filter or swiss cheese the stock airbox. As for warrenty just be smart and take the programmer off most times they dont care if you are good with the service guy and are consistent that is always a loaded question on the warrrentys. My service guy with my rig has no problems with what is done to it and its a lot more than a programmer and exhaust.
JPD Motorsports is offline
Old 05-03-2006 | 07:38 PM
ok...yea yea....lots of turbo whistle ...I am gonna run this thing out!
Byrdman is offline
Old 05-10-2006 | 09:33 PM
what is the overdrive bolt on unit i saw somewhere here???I am doing 2700 at 75....all other shifts bang out at 3300...maybe it has a governor or is tapped???the transfer case is seperate from the trans....someone said there is a unit for overdrive for allison trans....2005 model..
Byrdman is offline
Old 05-16-2006 | 04:29 PM
JasonSmith's Avatar
Byrdman, the bolt on is made by Gear-Vendors. I looked on their site & they don't show a model for the Allison.
Try a 2 speed rear end or a bigger wheel tire combo.
No homo jokes f*ckers!
JasonSmith is offline
Old 05-16-2006 | 10:30 PM
Yes....they do not...and have nothing coming......also..I can not hop it up cause medium duty truck computors and sensors for everything are different from light duty ....I will look into the 2 speed rear.....got any ideas like gear vendors....so i can keep it simple???....I really need to go faster than 75.....on the highyways it is killing me....I am stuck in the flow of traffic and sometimes have to go to the right .....2 speed rear....I will find it if they make it....great idea!
Byrdman is offline
Old 05-16-2006 | 10:46 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
They are quite popular in the RV towing world. You should be able to find one without too much trouble.
Sydwayz is offline
Old 05-17-2006 | 04:39 PM
JasonSmith's Avatar
Why not get really simple & change the gears in the rear end. Isn't that truck set up with a dump bed or something? It might have some big a$$ gears in it right now.
I'd go that way or find a bigger tire/wheel combonation.
Old 05-17-2006 | 06:41 PM
yes....what does it mean when it seems like you have a injector rapping...some blue smoke....then goes away....then when it is sitting there idling....there is a clicking noise....coming from within..deep....some say it is the same noise that the oil port issues in the first lbz??2 different issues....anyway that did not take long for me to have a warranty issue...this is probably why the previous owner dumped it...but there was no claims ....when I was going to the dealership it started pinging like....bad injector....then let a real damaging bang go ...after that it ran fine....i think it is mis firing a injector...not loading.....then loading to much......????
Byrdman is offline
Old 05-17-2006 | 06:59 PM
The truck is 4x4....with hauler bed....I would go for a 2 speed rear if it could be done...since I am the only driver...I do not want bigger tires...there no good for towing...plus it will be a eyesore for everyday use...it has 519 gears
Byrdman is offline
Old 05-17-2006 | 07:38 PM
JasonSmith's Avatar
519's on what size tires?
