Semi Tires on F350's ???
Re: Semi Tires on F350's ???
Originally Posted by Chuck
So bottom line, who here has done this and would you do it again?? Please post the good and the bad. I really want to do this set-up but there seems to be alot of controversy. I am thinking about the 19.5 so that I can do a direct bolt on with no brake or suspension modifications. ( 2006 Ford F-350 Duually 4x4). Thanks
answere to your question is yes, my next truck will have them on it as well. If i move up to an F650 it will have 22.5's
I went with the Rickson 19.5's with Goodyear G124 tires on my Dodge 3500 and have no problems. They are direct bolt on's with no adapters. If I did it again I would do the 22.5's.
How do the larger tires ride,most of the trucks are low profile in the pictures.I want to go with 22.5 and tall tires.How many inch are the semi tires?
Originally Posted by Byrdman
What do you guys do about gearing?
the 255 / 70 / 22.5 are 37" tall.
On a new Chevy you will need to have the ABS module reprogrammed to make the brake light error go away.
I tried changing the gears from 3.73 to 4.56, bt am changing it back to stock. I lost too much on the top end. As long as you have some sort of performance chip you should be fine with the stock gears.
Is there a direct bolt on Alcoa 19.5?? I like the look of those wheels with the big tires. I don't keep anything long enough to mess with suspension, brakes, computers, etc...
