do all aluminum trailers float????
I would recommend Iron 50 lbs. dumbbells U-bolted to the inside of the I-beams over the filled PVC route. I tried the PVC route first and it did not work for me. I made 4 that were 80lbs each and it still floated. The PVC itself is bouyant, and if you trap air in them, that's bouyant too.
I U-bolted 4 50lbs. dumbbells inside of my I-beams and it worked like a champ. After I rebuilt my trailer, added bunks, new axles, and an additional axle of brakes. I was able to remove two of them. I placed two inside the I-beams at the very rear of the trailer. I places two inside the beams just in front of the front axle. I was able to remove the front two. Make sure you coat the dumbbells with lots of paint as they are iron. I used 6 coats of black Rustoleum. Use SS U-Bolts and hardware, and find or buy a piece of rubber and cut it to strips to place between the dumbbells and the aluminum trailer. This will isolate vibration and keep dissimilar metal corrosion away. I thought I posted some pics of this a few years ago. This was on my POS Rocket Trailer. My current McClain Aluminum I-Beam trailer does NOT float at all.
ive got an aluminum under a 36' baja outlaw. it doesnt float, but it does move when its too deep and there is a strong current. makes for a beotch when its packed at the ramp and a hard current.
I would trade mine with $$ for a nice steel trailer anyday.
