C4500
Old 11-28-2006 | 04:24 PM
TeamSaris's Avatar
Driver-441
Racer
Default Re: C4500
Originally Posted by Catmando
The 4500 will be heavier than the 3500 so engine mods should be on your to-do list. They use the same Duramax powertrain if I'm not mistaken.
The F650 uses the Cat C7 which can be pumped up from 300hp to 425hp.
Our older 4500 had a duramax and it had plenty of balls.
TeamSaris is offline
Old 01-29-2007 | 10:24 PM
jeff32's Avatar
Default Re: C4500
pulling boats in lauch ramps...Are those 4500 2WD or 4WD ??? I'd be worry to use a 2WD in launch ramp.
So you guys are using 4x4, right?
jeff32 is offline
Old 01-29-2007 | 10:33 PM
racesdad's Avatar
Default Re: C4500
we bought a new 5500 crew cab for our raceboat. had 350. 650's. i like the 5500 better. you do need to remove spring though.
43,000.00 compared to 60,000 (ford)
gm with 12 foot box custom made 45,000.00 otd
racesdad is offline
Old 01-29-2007 | 10:38 PM
jeff32's Avatar
Default Re: C4500
2WD or 4WD ???
jeff32 is offline
Old 01-29-2007 | 10:40 PM
Default Re: C4500
Originally Posted by Chris Sunkin
Cat power upgrades are unbelievably expensive. At a minimum, the lower-end bumps (like from 200 to 250) require turbos and injectors along with a reflash. The bigger one's require pistons, dampers, fans, radiators and intercoolers and I think the biggest require cranks. Then you have gearing changes to address. Basically, if you are looking at a truck and think you need more HP, call Cat first.
Basically if your looking for hp.....buy a d max...forget the cat
Byrdman is offline
Old 01-31-2007 | 10:30 PM
bajaholic's Avatar
Default Re: C4500
I have had the c4500 for 3 years now, NO Problems pulling out, Our's is 2wd, no need for 4wd, it is a heavy truck. The only thing we do is make sure fuel is full if it is raining or LATE in season when water level is down.
bajaholic is offline
Old 02-01-2007 | 06:17 PM
jeff32's Avatar
Default Re: C4500
if you're pulling a 40 foot baja with a 2WD... Man I'm surprised you never got stuck... Not sure I'd take the chance... Anybody else on 2WD and no problem ?
jeff32 is offline
Old 02-01-2007 | 08:15 PM
bajaholic's Avatar
Default Re: C4500
Has never been a problem @ all, of course we are putting in on "good ramps". We boat LOTO 95% of the time. They are steep but paved.
4wd Is not necessary, the truck is heavy. How many semi's do you see that are 4wd and they pull LOTS heavier things all the time. I could see a smaller truck needing the 4wd, but the weight to pull ratio is substantially smaller.
If you drive the 4500 (for pulling) you would never gt back to a smaller truck.
Old 02-03-2007 | 08:16 AM
Default Re: C4500
If you have the proper tougue weight then you dont need a 4x4 truck
bgchuby01 is offline
Old 02-03-2007 | 08:19 AM
jeff32's Avatar
Default Re: C4500
1200lbs tongue weight. enough?
jeff32 is offline
