Brake controllers
Old 11-29-2006 | 12:25 PM
OldSchool's Avatar
Default Re: Brake controllers
Originally Posted by scottc
I sell the Draw-Tite Activator II #5500 and have no complaints. Works on up to 8 brakes on electric only. And all ele/hyd systems I have found so far. Some brake controlers have been know to not work will all systems or have load issues.
Good luck with your system.
How much are they Scott? Is there a plug on it or would I have to splice it with my existing plug?
Has anyone used the Tekonsha Prodigy with elec/hyd.???
OldSchool is offline
Old 11-29-2006 | 07:08 PM
Tony Montana's Avatar
The BAD Guy
That was the one I found seemed to be the best when I did research. I have not installed one yet so I can only go on what others had to say about it which was all positive. I called them to ask if it would work w/elec over hyd and they said it should but to check with the trailer manufacture to double check.
Tony Montana is offline
Old 11-29-2006 | 08:31 PM
rbtnt's Avatar
Has anyone used the Tekonsha Prodigy with elec/hyd.???[/QUOTE]
The instructions that came with my Prodigy said not to use it with elec/hyd. As Tony said, I would check with the trailer manufacturer to see what they recommend.
www.mtboats.com - Pages of boat related links
rbtnt is offline
Old 11-29-2006 | 08:40 PM
buck183's Avatar
Originally Posted by wrinkleface
I use the DTII. Have used it w/ 2 dif brake actuaters and it has worked great! Good luck!
This is also my best selling unit. Again, works great for us on Elec/Hyd brakes no problem. I like them because they are a simple straight forward brake controller. We put them in every truck that we do tow packages on for our dealers too.
Craig, yes you can use your existing harness with this unit. Just cut it off your old controller and wire it to the new one....no problem.
Buck
buck183 is offline
Old 11-30-2006 | 05:49 AM
Prodigy is the stock controller on Ford's, it works with my rig although the Ford manual says it will not and the manufacturer says it will not.
SkiDoc is offline
Old 11-30-2006 | 08:41 AM
wrinkleface's Avatar
Everybody is a genius!
wrinkleface is offline
Old 11-30-2006 | 09:28 AM
Tim G.'s Avatar
Performance Boat Center
Wink Re: Brake controllers
Correct you are... We have an '06 F350
It does NOT work with the Brake Rite pump found on Myco trailers. I have had no less than 10 different Mycos with Brake Rite pums on this truck. Not one worked.
Who needs trailer brakes anyway???
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 11-30-2006 | 02:25 PM
I have the Prodigy on my 2500 Avalanche- 2004- and it works great on my horse trailer- all electric brakes. I swear by it. I guess it may not work w/ the elec/hyd. set up though.
Wannabe
wannabe is offline
Old 11-30-2006 | 07:11 PM
CAVelocity's Avatar
I have the Prodigy on a trailer w/carlise electric over hydraulic actuator. Carlise sells an adapter that allows the prodigy to work without setting any errors. No complaints here.
CAVelocity is offline
Old 11-30-2006 | 10:16 PM
BZ's Avatar
BZ
"Tekonsa" "Voyager XP" Have this one in my 2001 Ford F-350 and it works like a champ with my Myco. But I will tell you that it takes a long time to get the brakes "set" up with this unit....BZ
BZ is offline
