Pulling with 8.1L Avalanche
Old 12-21-2006 | 02:55 PM
czy40p's Avatar
Default Re: Pulling with 8.1L Avalanche
Is it safe to assume that if the vehicle is rated to pull the load it is OK? I know that vehicles are constantly overloaded, but have people had bad problems with in the legal weight limits that were caused by the trucks? If the truck is rated for 7,500LBS on the bumper should they only pull 5,500LBS? I just do not understand all the passion against non-dually vehicles.
czy40p is offline
Old 12-22-2006 | 09:38 AM
Cattitude's Avatar
Originally Posted by Catmando
My truck is a 2003 Dodge 3500 Quad Cab SRW 4X2. It is rated for 11,500 at the receiver hitch and 14,500 on the gooseneck. I have never towed more than 5000lbs. I would probly TRY to stay 1000-1500lbs under the limits of both hitches just to be on the safe side. If I had a dually I would feel more comfortable towing close to the rating limits.
At least I can get mine in the garage.
My dodge is the twin, but 4x4 and rated for 23k gross combined. I've run it at a few hundred over with a g/n race trailer. engine is tweaked and have an ex brake. I tow 25k miles+ a yr racing. The SRW does fine, though I was close on the rear axle weight and tires. I do run a wider wheel and larger tires which IMHO helps with the load and potential heat issues. Too many dually guys with no seat time in a good SRW truck think the sky is falling
That said, there is no argument that wheelbase, weight, dual tires and way more tow capacity than needed in a tow rig gives a lot of margin when **** happens. Tow with a 270" WB FL70 toter mostly now
I'd think of the 8.1 Yukons and avalanches (shorter WB) as adequate for slower local stuff with larger boats- would be scary if stuff got interesting at hiway speeds
Cattitude is offline
Old 12-22-2006 | 09:50 AM
Elite Marine's Avatar
I have no issue at all towing with my 8.1 Avalanche.
Elite Marine is offline
Old 12-22-2006 | 09:57 AM
Cattitude's Avatar
Kirk- your boat is well suited for the rig- add 6 more feet, an engine/drive, 70-75 hwy speed and an oh **** on the hwy......
Old 12-22-2006 | 11:17 AM
WARPARTY36's Avatar
Drive to arrive alive!!!
I would prefer a dually, but my old Sub towed fine. It's the same platform and engine that's in the Avalanche.
Attached Thumbnails Pulling with 8.1L Avalanche-burb.jpg   Pulling with 8.1L Avalanche-driveway.jpg
WARPARTY36 is offline
Old 12-22-2006 | 11:22 AM
Sydwayz's Avatar
Forum Regulator
Add the rear wheel spacers. They are worth it, and they make the rig look better too.
Sydwayz is offline
Old 12-22-2006 | 01:14 PM
rrentsch's Avatar
Registered User
Smile Re: Pulling with 8.1L Avalanche
Thanks to all you Avalanche and Sub. guys for the comments and Pics. I'm starting to feel alot better about My move up to the 34'
rrentsch is offline
Old 12-24-2006 | 11:29 PM
pleeeeze...you guys want to here what you want to here....and you do not stop untill you here it....that truck is not capable of doing that load with a good margin of safety due to other people on roadways these days....and you feel good....pleeeeeze....I have ridden in this garbage you guys call tow vehicles....not a pretty picture as your stating...or as anybody has stated...with no problems....your just plain full of crap period...excursions suck....subs suck....basically all of the single wheel vehicle suck for safety on the road...they all get jammed up all the time....but they won't tell you.....just like bernie....besides...you know better already...you just want to feel better about making a mistake .ask bernie...ask bernie
Byrdman is offline
Old 12-25-2006 | 09:46 AM
Sydwayz's Avatar
Forum Regulator
I can understand Byrdman's harshness. Everyone has opinions.
Not everyone can afford or justify a C-4500 GM or even a 1-ton Dually. I know I was at that point; and now I own a dually, and its 7 years old (in better than new condition). I know FROM EXPERIENCE that towing with the Avalanche/Suburban 2500 platform can be done JUST FINE based on setup. I also know that towing with my 1-ton dually is all around a better package, but its not the right setup for everyone.
Sydwayz is offline
Old 12-25-2006 | 10:39 AM
Cattitude's Avatar
More food for thought.......
Is a dude safer in a 1987 chevy BB dually at 131" of WB or in a newer burb / Avalanche, SRW, same WB, with 4 wheel ABS (assuming each is well set up with hitch weight trailer brakes etc)?
Most OTR and local trucks in Europe and Asia are all rolling around on super singles on the drive and steer axles.
2 dudes hauling the same 35' boat, one with a borderline but legal SRW tow rig, the other with a 550 kodiak.
The borderline guy knows he's on the edge and stays 55ish for his short 30 minute ride and leaves lots of distance ahead of him and slows down ahead of the stoplight/offramp/intersection.
The 5500 guy thinks he's superman with his mondo truck, 19.5 tires, huge brakes and runs hard, lulled into overconfidence, following at close distances, 5 over the posted 70 limit, drinking a coffee and making a quick call to his buds who are meeting him at the ramp 30 minutes away.
Who is more dangerous?
Point is, there are a lot of variables that go into safe driving, safe/adequate equipment and setup and not everything is absolute.
Merry Christmas and happy safe towing
