'99 Tahoe multifunction switch replacement.. help >
Old 01-22-2007 | 09:38 PM
satisfactionII's Avatar
Default '99 Tahoe multifunction switch replacement.. help
It appears my Tahoe has a bad multifucntion switch or wiring problem. Whenever I move my tilt-steering wheel the headlights go off. The headlights also turned off one time when using the right turn signal. Does anyone know how to remove this switch out of the steering column? It sure gets dark at night without any headlights.
I have searched the 'net for this answer and can't seem to find a complete answer.
Thanks in advance.
SAR
satisfactionII is offline
Old 01-22-2007 | 10:22 PM
Default Re: '99 Tahoe multifunction switch replacement.. help
Your Going To Have R&r The Air Bag And Sterring Wheel Just To Get At It,take Off The Gauge Bezel And Upr And Lower Colum Covers
dmaxx3500 is offline
Old 01-22-2007 | 10:29 PM
No big deal.
3 25 torx screws on the buttom side of the steering colum cover.remove them,pull out the tilt lever.split the steering cover and remove the buttom piece,now remove the 2 inverted torx screws that hold the upper cover in place.all you got now is 2 25 torx holding the multi function switch in place,one on top and one on the side.after thats done follow the wireing harness to the connector and using a 7mm socket loosen the connector.for the most part that petty much it.
make sure to push the horn contack in when installing the new switch
good luck
boatnt is offline
Old 01-22-2007 | 10:37 PM
Thank you guys for the info. While looking on the 'net I found that this multifunction switch is a real POS. Love my chevy but sometimes .......
Old 01-23-2007 | 12:10 PM
Registered User
Disconnect the battery!!!!
Chris Sunkin is offline
Old 01-23-2007 | 02:54 PM
I thought about doing that. Thanks for the reminder.
Blue by You
Cigarette
22
02-10-2018 07:19 AM
Sydwayz
07-05-2007 09:40 PM
East Coast B
Sonic
4
07-05-2007 07:51 AM
jjj
7
06-05-2006 09:08 AM
mr_velocity
0
09-30-2003 01:12 PM
