View Poll Results: How much do you tow & with what? Select all that apply
0-5000 lbs
11
9.09%
5000 - 10000 lbs
51
42.15%
10000 - 15000 lbs
57
47.11%
15000 +
12
9.92%
4x2
8
6.61%
4x4
91
75.21%
Single Real Wheel
70
57.85%
Dual Real Wheel (Dually)
33
27.27%
Diesel
73
60.33%
Gas
39
32.23%
PU Truck
75
61.98%
SUV
22
18.18%
Multiple Choice Poll. Voters: 121. You may not vote on this poll
What Do You Tow With?
Old 02-08-2007 | 08:13 AM
Blue by You's Avatar
FIERCE ALLEGIANCE
Default What Do You Tow With?
Mark your closest answer...
Blue by You is offline
Old 02-08-2007 | 11:21 AM
cigrocket's Avatar
Default Re: What Do You Tow With?
Dodge 3500 V-10. I tow the Mistress. Its a 4x4 Dually
Attached Thumbnails What Do You Tow With?-1.jpg   What Do You Tow With?-2.jpg   What Do You Tow With?-3.jpg
cigrocket is offline
Old 02-08-2007 | 12:08 PM
AKA NoMoBoatin
A truck.duh.
docmanrich37 is offline
Old 02-08-2007 | 12:31 PM
5PMSMWHR's Avatar
2006 2500 HD Duramax / Allison, Putnam Class 5 hitch
1996 Polaris SL900 on Aluminum Triton
5PMSMWHR is offline
Old 02-08-2007 | 01:33 PM
From: A tree somewhere in the woods in Clarcona Fl.
06 Ford f350 swb diesel 4x4 dually,,,,04 Formula 27pc.
Slick02 is offline
Old 02-08-2007 | 01:45 PM
Thumbs up Re: What Do You Tow With?
2006 F250 Supercab, 6.0, SRW, pulling 35' Mistress
Harvey is offline
Old 02-08-2007 | 01:48 PM
30 outlaw 2005's Avatar
2005 Silverado 2500 Crew Cab Short Box LT Duramax Diesel with 5 speed Allison Trans
2005 Baja 30 Outlaw
30 outlaw 2005 is offline
Old 02-08-2007 | 04:54 PM
FIERCE ALLEGIANCE
WOW, not many 4x2's out there??
Old 02-08-2007 | 05:02 PM
Sydwayz's Avatar
Forum Regulator
4WD is worth $1 Million Bucks when you are slipping down a wet/slimy ramp backwards, spinning one rear tire.
I've gotten my dually stuck in my yard before in 2WD. I would not buy a truck without 4WD.
Granted, my Ford is a superior power machine compared to his D/A 2500HD , but when Rich was pulling Monsoon up the ramp at Bernard's Landing last fall, the Ford broke all 4 rear tires loose and sat there spinning. We were forced to use 4X4 to get up the ramp once Rich found the switch on the dash.
Sydwayz is offline
Old 02-08-2007 | 05:50 PM
mwdill's Avatar
well thats the problem,
Rich is not use to the power a ford can make! :
mwdill is offline
