What Trans Fluid for My Allison ??
1 Attachment(s)
I have been running the Valvoline Dexron III/Mercon in my Allison transmission in my 2003 Chevy 3500 Truck.Is this fluid OK ?
DEXRONŽ III/MERCON http://www.valvoline.com/pages/produ...asp?product=64 |
yes...that is what is in mine...2005 allison 1000
If you want to use a synthetic use Syn-Tran by Castol.You will feel the difference over Dextron 111
the name Dexron means is is GM approved;
DEXRONŽ -III This is a specification for General Motors vehicles, but many foreign manufactures specify a DEXRON approved ATF as well. DEXRON-III can be used in transmissions that call for DEXRON-IIE or DEXRON-II. http://www.chevron.com/products/prod...ntent/atf.shtm |
Originally Posted by 28brave
(Post 2051733)
Trans-Syn D. Proprietary Castrol for Allison product. Only available at Allison shops. I just happen to have one right around the corner. :cool: The 5 gallon pail is the way to go Spin-on Alli filters $7.85 there too. You won't "feel" a difference with Tran-Syn D but your tranny will. :) other than that yup, Dex III |
Changed my trans fluid for the first time not too long ago and have started using Amsoil. My Dad is a distributor, so I can buy it at cost and I think it is a good product. We shall see. I'm putting 8-10k miles a month on my '05 Allison, pulling a 40' flatbed and loads up to 15k lbs., so I'm hoping it performs as advertised.:cool:
http://www.imagehosting.com/out.php/...8_atd1g300.jpg |
2nd vote for Allison TranSynd
its a gm, just use water, it should be fine.....
Originally Posted by stecz20
(Post 2053360)
I heard...that you were not supposed to switch to anything....I had a stage 5 hop up.. heavy 5 pack sun convertor plus I just put a extra gear...6th.. and all kinds of tricked out stuff....and they did not say anything about this other stuff...hmmmm...plus....you are not supposed to change any oils from what you have been using from the start I thought..????...also when you take the pan down...get the magnet out and put it on the bottom of the filter....or get another magnet...you will see if they got it in that year...looks like a 2 inch washer....
| All times are GMT -5. The time now is 12:01 PM. |
