Truck Breaks
Old 03-22-2007 | 06:29 PM
itilldo's Avatar
Originally Posted by Chart
Ask them to prove the need with facts. How worn down are your pads vs. new? If you don't feel a vibration when using the brakes, why do they want to grind material off the rotor? (some thinks that makes new pads stop better, some don't. But all agree it adds to the shop's profit). The biggest "red flag" I see here is if they also say the rear brakes need replacing. They usually last through two sets of front pads. If the shop can't provide factual data to justify an entire brake job and rotor turning when you don't feel any vibrations, I'm betting they are trying to make money off of you.
BTW: I've driven a PSD Excursion as my daily driver for 5 years, and do the brake jobs personally in the driveway. I know how simple it is, and am shocked by how some shops take advantage of some customers.
BTW#2: The best thing to prevent rotor warpage in the future is to torque the lug nuts down to 170ftlbs. If your shop does not know to do that, then they are not trying very hard to decrease your needing future repairs.
there was some chatter when I hit the breaks and since the work there fine. I'll look at getting some different rotors in the future.
itilldo is offline
Old 03-22-2007 | 06:31 PM
Registered User
I was going thru pads & rotors on both Excursions. I bought Powerslot rotors and EBC green pads for boty of them. Brakes much better, no pulsation and the wear has disappeared.
Ford makes lousy brakes.
Chris Sunkin is offline
Old 03-22-2007 | 07:08 PM
Just reread your first post, and No, surge breaks on the trailer should not cause the truck brakes to wear faster. That's assuming a couple of things though, like the trailer brakes are in proper working order, and they are sized correctly for the trailer load.
Surge brakes are a clean and simple way to stop a trailer, and when serviced and adjusted properly, they work great. You'll hardly know the trailer is there during normal brakeing. The problems occure when they are neglected and don't work as intended. In those cases Yes, the truck brakes can get a hard workout.
Most surge brakes are free-backing DRUM brakes, and therefore do not auto adjust the shoe towards the drum. So as the shoe weats down, the gap between it and the drum increases, reducing overall braking ability. You might want the trailer repair shop to adjust your brake shoes once a season or so depending upon how you use the trailer. Disc brakes don't have this worry, and are better all around, but usually only found on new higher dollar trailers.
Next, the surge coupler itself need to be serviced to ensure a smooth sliding during braking. The trailer repair shop can check that out at the same time. From there, you should be good to go.
One last thing, when drum brake shoes wear out, it is cost effictive to replace the whole backing plate instead of just the shoe. But you might want to price a disk convertion at that time instead. They really do stop that much better.
Chart is offline
Old 03-22-2007 | 07:15 PM
i have a 05 chevy had to replace mine at 17,000
ext2gtx is offline
Old 03-23-2007 | 07:42 AM
hunster's Avatar
Powerslot rotors I put on my expy are crap. Warped in no time , normal driving. Also used the ebc green pads , like the low dust compared to the ford pads but they must be killing the rotors. I think I'll try hawk pads or just go back to stock.
hunster is offline
Old 03-23-2007 | 09:53 AM
Mike Paula's Avatar
I have Bosch Ceramics on the front my F350 w/ stock rotors and love them
Mike Paula is offline
Old 03-23-2007 | 10:52 PM
yesrej's Avatar
get drilled or slotted rotors. you will pay for them but will last much longer. lets the brakes breath more and lets out more heat. it is worth the investment. brakes are not something to cheap on. i replaced mine on my dodge ram and im very happy with the money i spent.
yesrej is offline
Old 03-24-2007 | 05:33 PM
drilled and slotted rotors arent the ticket it only removes material that
can be used for clamping pressure. they also promote hairline and
spider cracks. i road race and see extreme brake rotor temps. if you
would like your rotors to last longer cyrogenics has been a help to
rotor longevity.
PowerplayDave is offline
Old 03-24-2007 | 07:18 PM
DirtyMoney's Avatar
I have been over 100k on a superduty f250 with brakes towing as much as 17k on a regular basis. I guess I start stopping sooner.
DirtyMoney is offline
Hot Boat
31
11-22-2010 04:02 PM
Formula Outlaw
03-28-2005 09:28 AM
boot
01-24-2003 04:53 PM
