BrakeRite claims thier e/h is compatialbe with the Ford controller.
Originally Posted by WARPARTY36
(Post 2084110)
Another thing I noticed. The factory brake control is not good for electric over hydraulic brakes:rolleyes: It will work if you manually move the control, but not with the brake pedal.
I though something was odd, then looked in the manual, and it confirmed it.:mad: you should be used to that by now.... :D |
My Brake rite works great with tow command on my 06
Originally Posted by Catmando
(Post 2082439)
If I had to pull 24,000lbs(which is what the F450 is rated to tow), I would go with the F650 and the Cummins/Allison powertrain.
| All times are GMT -5. The time now is 02:14 PM. |
