Insurance people? Tires and the factory rating...
I was recently told that because I have a 2500HD Chevy and I run Nitto Terra Grappler's that are not "E" Rated as the original equipment tires are, that my insurance company wont cover me or my truck in an accident... Has anyone heard of this or can you confirm it??? I don't tow very much, so I didn't put back E rated tires but I certainly don't want to screw myself...
Thanks, Ben
Thanks, Ben
Registered User
Insurance companies are always on the lookout for ways to reduce their exposure. If having improper tires causes or contributes to a loss, they very well may deny or reduce your claim, and rightfully so. If you run a red light and cause damage, it's unlikely that they'll look at the tire's weight-rating in determining if they'll pay.
What you should really be worried about is if your lack of tire rating is going to send you on a roller coaster ride that you may not survive.
I have D-rated tires on my Excursions but I don't tow anything bigger than a 20' boat with them. Factory calls for E's.
I don't tow big boats anymore. I tow my 18' flats boat and my 14' Shifter Kart trailer and neither weigh very much. I do understand the insurance companies not wanting to cover something that would be caused by the tire failure that could have been effected by the rating but I was just wondering about overall coverage. Thanks...
Registered User
Keep in mind, each state has their own laws governing insurance companies and each company has policy (contract) language for each state it does business in. Essentially, it only matters what your contract says. If it's not included or excluded, either specifically, categorically or generally then it doesn't exist. I did a repair on my home based on the insurance company's estimate, then called them for the check. The sent it with 10% deducted. I called and asked why. They told me it was their "policy". I asked if they could point to the section in our contract that provided for that deduction- they mailed the balance. Read your policy. The thing is, even the vaguest language can give them the wiggle room to deny, thus forcing you to litigate. Unless there's significant negligence and huge settlement costs, they'll settle before they fight. Unless there's big $$ involved, they'll probably send an adjuster that knows bodywork but probably couldn't change a tire, let alone see that a marginally under-rated tire caused the accident.
Mitch
In most cases the only time tires would come into play is if a tire failure caused or contributed. And then only if they could prove the tires were overloaded. This does become an issue with lowered trucks with car tires on them (overloaded empty). In your case it is a stretch that an adjustor would try it.
frequentflyer
09-02-2003 09:33 PM
Mr. Demeanor
04-15-2003 10:45 PM
