-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   How much fuel would a 6.0 PSD (https://www.offshoreonly.com/forums/trucks-trailers-transportation/158958-how-much-fuel-would-6-0-psd.html)
masher44 05-22-2007 10:05 PM
burn if you ran it for 6 hours at idle?
klmken 05-22-2007 10:17 PM
6 gallons...I heard about a gallon an hour from those with PTO's or accessory generators....I get 20 mpg from my 04 excursion HWY w/edge chip!!
spk1 05-23-2007 03:06 PM
Depends if you like the a/c on high,med,or low while you sleep. :evilb: :evilb:
382 newbie 05-23-2007 06:56 PM
I'm going through some turbo issues, coking and the variable boost vane sticking. The dealer attributes the sticking to long periods at idle. I typicaly start my truck in the morning, come back in the house get my coffee, check my email and then leave. which amounts to about 10 min..they said that was too long..6 hrs..idunno
ZBODaytona 05-24-2007 09:08 AM
read somewhere if you are going to idle the 6.0 need to have the high idle feature....(just taping a wire and putting a a switch on)...if you don't you can wash the cylinders.....again just what i have seen others say.
tblrklakemo 05-24-2007 10:55 AM
you probably need the high idle deal.....but in all honesty diesels are suppoesed to be able to run long periods of time. Every dealer will probably say something different. Why do you need to run it that long? Sleep? Just get a cigarette lighter fan for comfort.
Son of a Gun 05-24-2007 02:14 PM
I wonder if that's a standard feature on some models. The old man's '07 6.0 starts to idle high on its own after a little bit.
Sea-Dated 05-24-2007 06:22 PM
Did you sleep in it or did you fall asleep and leave it running?
spk1 05-24-2007 08:41 PM
http://www.youtube.com/watch?v=G9zJ0CkgLaU
:evilb: :evilb:
Panic Button 05-24-2007 09:02 PM
My '06 6.0L will idle up (1200 rpm) after a while to prevent the wet stacking, after about 5 minutes it drops back down. There is also a wire that you can jump to the up fitter switches to do it manually.
