Best Truck Alarm?
Old 07-02-2007 | 08:58 PM
Rcrapsey's Avatar
Get Down
python is the chit
Has all your looking for and what's a few more $$ to protect your ride I also put on in my Donzi
Rcrapsey is offline
Old 07-02-2007 | 10:29 PM
hunster's Avatar
Python is a re boxed Viper. All dei brands are the same or similar with the exception of clifford. Viper does have the lifetime warranty but as stated only if installed by a legit dealer. I have sold the Viper brand for 18 years and think they make a first class product. If you want something a little tricker , Clifford has some neat features but you need a lot more wiring and a pc and software to program. The viper you can program with the valet switch , I use their handheld programmer , much easier. Instal on your truck is pretty straight forward. Lots of diodes to isolate the door triggers at the bcm , thats the only thing. There is no real good tach source on the 6.0 , sometimes it works , sometimes it doesn't. I have to use a tach generator on the alt 1 in 10. Can help you with the wire colors if you need when you choose an alarm.
check out the Clifford though. www.directed.com
hunster is offline
Old 07-02-2007 | 11:24 PM
We are a DEI and Omega shop primarily. You can't go wrong with either of them. If you want a full featured setup, take a look at Hornet 564T's. Does everything you want (with optional accessories), 2 way pager, decent range, etc etc. They can be found for ~$150.
I do have some beefs with DEI though. You'll have wires coming out of 3 of 4 sides of your brain. Other manufactures are able to use 1 or 2 side, which makes tidyness and cable routing far easier. Their lock outputs are underpowered and they don't have a pre-delay option for diesels, instead you have to use a DPT. Again, other manufactures (Omega for example) have a programmable predelay of 10 or 20 seconds, or via the wait to start wire, but on the new trucks the clusters are all digital and you can't pull a wait to start. Also, DEI's voltage sense is generally garbage, where Omega's is far better. Using voltage sense saves running another wire under the hood to pull a tach and is generally a time saver for us.
You may want to check out the Omega MaxE w/ the Echo2 upgrade. It doesn't have as many features as some of the DEI units, but then again, IMO DEI has a lot of useless features and doesn't have what should be some standard features (such as a solid voltage sense and diesel delay option). Had I done it over again, I probably wouldn't have used a DEI system. In fact, when I find a Dodge or Chevy 2500 (diesel of course), I'll be installing the MaxE system.
LordAthens is offline
Old 07-02-2007 | 11:29 PM
Originally Posted by Tony Montana
And also since my 50k truck is just that I also like doing my own work so some punk doesn't phuk it up!
I can totally understand that. Unfortunately, it seems like it's getting harder and harder to find a reliable shop that cares. I pride myself and my store and the guys that work for me. Meanwhile we get jacked off customers from the guy down the road that only wants to make a buck. It seems very hit and miss. I'm in a slightly more niche market though, as we cater to primarily trucks, though we do a lot of car remote starts during the winter.
Good luck with the install.
Old 07-03-2007 | 07:57 AM
From: A tree somewhere in the woods in Clarcona Fl.
Ultimate Audio installed an Autopage RS-860 lcd unit in my 06 F350 6.0 and the remote start has never failed me and it has excellent range. and the alarm has worked fine, and was noticibly less expensive and less complicated than the Viper, and for what its worth, on my 04 F250 I tried the ford marketed unit(mfg by Code Alarm) and it was the biggest pos I ever saw, no range, inconsistent remote starts, etc.
Not gospel, just my opinion from personal experience.
Nick
Slick02 is offline
Old 07-03-2007 | 08:10 AM
Tony Montana's Avatar
The BAD Guy
Found this autopage unit. Says has a mile range and diesel compatable?
http://cgi.ebay.com/ws/eBayISAPI.dll...0644&rd=1&rd=1
Tony Montana is offline
Old 07-03-2007 | 09:09 AM
buck183's Avatar
The tach wire under the dash on the 6.0 has worked perfectly for me since day one. I actually find it to be the easiest Diesel to install a remote start on. Although we don't even need a tach wire on the Duramax or Cummins.
Buck
buck183 is offline
Old 07-04-2007 | 08:31 PM
Tony, that appears to be the new super duper updated one to the one thats in my truck,,,like I said, had 0 problems out of my Autopage unit.
Slick02 is offline
THEJOKER
33
12-19-2007 09:09 AM
bouyhunter
26
11-12-2006 01:47 PM
PWRCAT
16
06-01-2005 05:47 PM
RutRow
2
09-12-2004 05:39 PM
waden54
12
06-06-2002 10:12 PM
