-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   First post, first boat, tow questions... ! (https://www.offshoreonly.com/forums/trucks-trailers-transportation/164069-first-post-first-boat-tow-questions.html)
pangris 07-20-2007 11:53 PM
Hello! Looks like a great forum.
I have a pretty simple question, but with some depth based on the situation.
My friend and I are buying a boat (cow?) together. We're looking at 27-31 foot Fountain center consoles.
He has a F-250 PSD and a lot of experience towing/driving big and long stuff.
I have an Expedition with the 5.4L engine, rated to tow 9000 lbs.
I don't *need* to be able to tow the boat, but I'm wondering what the normal limit of an Expedition is considered to be.
I'm not planning to tow much, if ever - but if I find myself in a situation where I can't borrow his truck, can the Expy hand a 27... 29... etc?
Thanks!
East Coast B 07-21-2007 09:54 AM
Where are you towing? Flat or hills? I'd think you'd be fine with a boat in teh 27-29' range, may have to beef up your rear suspension. Anything bigger, might be a problem. This is just guessing as you don't have any specific specs on the boat. Remember, boat weight is dry weight. You have to add for fuel, gear, etc. Then add the trailer weight. In my opinion, if a truck tow rating is 9000lbs, again my opinion only, I'd take 1-2k off that rating. Now, I live in a hilly area. I used a yukon to tow a 26' boat and it didn't take me long to order up a bigger stiffer truck. Again, I'm in hilly areas and coming down the hill braking, I could feel the truck twisting under the weight of the boat and the trailer had tandem disk brakes. It did the job, just wasn't comfortable with it. Now, same rig down South on the flats.... No problem... Didn't specifically answer your question, but hope the info helps!
Chris Sunkin 07-21-2007 10:59 AM
It depends on your Expedition's equipment but ballpark you're at or over it's max towing capability. The F250 would do the job well.
Zudnic 07-21-2007 01:12 PM
The Expedition and Lincoln old style Navi's shared the same platform and almost the same body. I know this cause my 98' Navi needed a driver's door and an Expidition was the donor!
My question then would be; does the Expedition also share the air ride suspension of the Navi? If the answer is yes (cant remember if they do), then would be concerned about putting the strain of the tongue weight on the rear, when it self levels under this load; maybe it can take it, but thats going to wear the suspension. Not a good bill to repair these supensions, I would defiently look into an F250 PSD, if it was me and it does have the air ride.
FROGMAN524 07-21-2007 04:09 PM
Buy a Duramax/Allison 2500HD. Then you're in business.:evilb:
pangris 07-22-2007 11:58 PM
Thanks for the replies! I'm in southern Louisiana, so we are flat as a board. NO hills. On/off ramp for the interstate it the most elevation I'll see.
I have a 5.4 Eddie Bausr with the AWD/4WD and Advanctrac... don't know about the rest, but I'll find out.
Sounds like, bottom line, in a pinch the Expy could work.
In reality, the Expy is the wife's - I drive a BMW sedan that isn't hauling anything other than ass :D I know she doesn't want to drive an F-250, and niether do I.
Bottom line - sounds like on flat land, it sounds like I should be able to safely tow 7500-8000 lbs on a good trailer IF push comes to shove a couple times a year.
About right?
Thanks again!
Chart 07-23-2007 09:14 AM
Sounds about right. But be careful and slow.
pangris 07-23-2007 11:13 PM
No worries there. I'll be that slow guy with the boat :)
stott71 07-30-2007 10:06 PM
Pangris,
I haul nothing with my 2006 330i either! Oh yes, except ass:) But I'm in the market for a truck to tow my 5500 lb 28 Wellcraft, add 700lb for fuel, 1100 for trailer, 200 for gear and I guess I need to be prepared to tow 7500lb. After seeing a local guy towing a 10,000lb Baja 38 special with a 1/2 ton Chevy Avalanche (he said he'd never had problems, but always used 4WD low on the ramp) I'm thinking you and I would be just fine using 1/2 ton truck or expedition/tahoe. Not too many hills where I'm from in Richmond, VA either.
fountain 47 sc 07-30-2007 10:40 PM
I have a fountain 47 and i am trying to decide whether to purchase a new for f450 pickup or a heavy duty truck. The boat and trailer together weigh about 20k dry weight. Any suggestions?
Indy 07-31-2007 07:13 AM
Originally Posted by stott71 (Post 2217635)
Pangris,
Check your GWVR and add those items you mentioned above and make sure you're within the limits. The insurance company will give you big balls if you're involved in an incident and you're over the limit, not to mention the saftey of yourself and others. That dude with the Baja is looking for trouble. If he is ever in a panic situation that Baja will throw that 1/2 ton around like a stick. The GWVR of that Avalance is about 7200lbs and it weighs 5700lbs, add in the tongue weight, fuel, cargo, people, blah blah blah and he's over. Also make sure your hitch and ball are up to the task as well. There are many good hitches out there and they're cheap to have installed.
