Tandem dually vs triple axle
I have a tandem dually Myco trailer which has 24.5 Alcoas, Goodyear commercial tires, and 15,000 lb. solid axles. It tows great but the boat sits fairly high on the trailer. It isn't really made for wet launching, but I replaced the axle seals and it has been fine. I have been thinking of trading it for a triple axle gooseneck, but wanted some thoughts.
I had a tandem dually under the Apache and switched to a triple axle gooseneck. The tandem duals are fine, but they can be a pain in the a$$ to change a tire if the flat is on the inside dual. One more thing that I considered is that when it comes time for new tires on the trailer, I only have to replace seven (6 plus a spare) with the triple axle instead of nine (8 plus a spare) with the tandem dually.
We went with a gooseneck for the new trailer because of the weight and length of the boat. The gooseneck will put the tongue weight directly over the rear axle of the tow vehicle and will also allow you to jackknife the trailer if needed in tight areas.
Either trailer will work well, but these are the reasons that I made the switch when I built a new trailer. I don’t think that I would change just to change, but if you are replacing the trailer anyway it might be something to consider. Here are pictures of each trailer.
I did tow the boat on the gooseneck with my 2002 F-450 and it did the job well, but it was over it's legal weight so I sold it and bought the Pete to keep things absolutely safe and legal. I have not towed the boat with the new 450 yet, but I will post the results when I do.
As you know I tow all kinds of trailers. Yes the two axel is higher but if you get a flat tire you still have the other one to get you to a service station. If I was building a new large trailer it would be a dually gooseneck
What would be the main reasons for going back to the f450 from the Peterbilt? (other than the increase in towing capacity). I would think that once you have the Peterbilt and are happy with it that it would last forever.
