F650
What kind of mileage does the F650 with Cat c7 and alllison trani get on the highway? Towing?
I see that OSO is selling their tow truck in the classifieds. Maybe they can answer. How is the ride? |
Ride depends on tire and wheel size, air ride seats, how the air bags are adjusted, what front leafs you have, adjustable shocks???
The more tongue weight the better the ride. It rides rougher than a Fl and better than an International. I drove every truck before I purchased, call me if you need more info. Our C7 is turned up 30 horses, has the speed limiter moved back, and has an exhaust brake so we may have different results than others. Worse case with a 15k load I saw 6mpg, 12k load more like 8-10. |
most 3126 cats get 8 - 10 mpg loaded. Cats don't care what the load is behind them
I have a fleet of Mack Trucks. 5 MPG, loaded or unloaded, no better, no worse.
Peterbuilt with 425 hp, turned up pump, 4 mpg. I love the OSO truck. Why are you selling it? I need a truck of that size to pull my new to me Formula 382 My F350 will have its hands full, stopping especially. |
Pardon my ignorance I just bought a 382 and am expecting the trailer brakes to stop the trailer. Am I wrong?
rjr |
Originally Posted by rjr
(Post 2309971)
rjr |
Originally Posted by Mackattack
(Post 2307946)
rjr, the trailer brakes should do most of the stopping, but from my experience, electric brakes are not always there when you need them. I pull a 40' gooseneck trailer used to haul construction equipment. The constant bouncing and jarring of the trailer seem to break wires, cause bad connections, etc. Sometimes your trailer brakes work, and sometimes they will not. I re wired the trailer, and in about 1 year, problems start again.
I have learned not to ever depend on trailer brakes to stop you. I always leave enough room for the truck to stop the trailer, if the trailer brakes work, fine, but if you press the pedal, and you only have the truck stopping you, you will end up with a hole in the middle of the driver's seat. The only trailer brakes (in my opinion) are air brakes. If you have air pressure, you have brakes, if you loose air pressure, you will have a warning on the guage. If you have a a wire break, or a brake controller take a crap, you may not know it until it is too late. This information comes after I ran into a truck from the rear in a F350 dually with a 40' trailer loaded with a backhoe. Trailer brakes failed, not enough following distance. |
(Post 2312129)
I agree that the brakes work very well. It is just my experience that one broken wire can cause you to have no more trailer brakes.
Thanks for getting the trailer and boat ready. Jason with Full Throttle will be calling you to arrange pickup. I think he wants to pickup on Monday afternoon. Thanks again Plumberscrack |
| All times are GMT -5. The time now is 03:30 PM. |
