What do I need to tow ............
From: Ocean Pines, Maryland. Wish I was at MANGOS in MIAMI!
There is a shift sargeant in a town that patrols the best large launch into Lake Michigan on the Illinois side. He stops everyone that is trailering over 10K. It doesn't matter that it is private; he still writes the ticket. It was much easier and less expensive ($60) to get a CDL than argue because each time to contest a ticket, you must waste the day to go to court.
no problem, Im actually trading it in, or offer it to my subs or friends can buy it from the dealership for a in and out for the same 35k they gave me, PLUS document charges of 300.00 . Wholesale numbers for a barely used nicely modded out truck. The only reason I do this every year is the 33k write off, and this year cause the economy is terrible my incentives @ 4030.00 which are higher than prev. years, plus at invoice my actual pmt goes down 70.00. No brainer for me. I lose the modded stuff like Air intake, Turbo Back Exhaust into duals, and the cosmectic stuff. Good Luck in whatever you get, they are good, thanks to competition. Jeff
Registered User
Yeah- right now Ohio is kicking off a big enforcement campaign for front licence plates. They're putting red-light and school zone cameras up everywhere and they need to read the plates.
In VA a Class B cdl trailer is limited to 10,000 lbs if the trailer gross is more you must get a class A. I have commercial tag on my dooley which as Chris said lets the legal gross weight go up. Passenger tags on a pick-up here only are 6500lbs. My dooley alone is 6400lbs so actually when I get in it I'm really over by 100 lbs.
08 will be here in Jan.
